Tire pressure sensor question?????
Old May 7, 2012 | 12:02 PM
Vinniety's Avatar
Vinniety
Default Tire pressure sensor question?????
I am in the process of getting tires for my wife's 2004 gx 470 and i before i do so i need to resolve the tire pressure light staying on. The spare tire had a TPS but it broke off. I had a local guy remove tire take sensor out and replace with standard air valve for the time being. The question is this.....does the monitoring computer sensor the spare tire as well???? Also what is the easiest way to test for a bad tps without bring to dealership?
thanks
Old May 7, 2012 | 12:56 PM
BlairC's Avatar
BlairC
Yes, the spare tire is monitored. You are likely getting a light because you removed the TPMS from the spare.
Ask your tire shop if you can purchase a new unit for the spare and if they can reprogram all 5 units into the GX. Otherwise sounds like you might be in store for a trip to the dealer.
TPMS. More hassle than its worth in my opinion.
Old May 7, 2012 | 02:37 PM
Vinniety's Avatar
Vinniety
Thanks for the reply but the problem is I had the light on before I took down the spare and broke the tps. I couldn't get the air cap off and using a pair of plyers just broke it. So...I'm not sure if the spare tire tps is even brok causing the light in the first place. Is there a way to figure which other one is broke? You never know it could have been the spare the whole time. Thanks
Old May 7, 2012 | 05:09 PM
Muti007's Avatar
Muti007
If youre certain the air pressure in your other 4 tires was good, likely the pressure in your spare was already low and that set off your TPMS warning light. Then you had it replaced with a non TPMS valve and the light never went away. I can almost guarantee that is/was your problem.
When I bought my truck, my light was on as well. I checked all my tires and all were good. Damn light wouldnt go out. Checked my spare while still mounted under the truck, and it was a few lbs short. Inflated it and bingo, no more light and it never returned.
Replace your valve with a correct one then inflate to proper pressure and Id bet youre all set.
Old May 7, 2012 | 06:09 PM
RCsGX's Avatar
RCsGX
And this time use plastic valve stem caps.
Old May 9, 2012 | 05:46 AM
Vinniety's Avatar
Vinniety
I found a tire pressure sensor on eBay that will replace the bad spare one. Once I get it I will I stall it in the spare and see where I stand if it resolves the issue turning the light off or not. Will keep everyone posted. Thanks for all the help!
Old May 10, 2012 | 12:14 PM
clubsport's Avatar
clubsport
sensors need reprogramming
Old May 10, 2012 | 12:57 PM
Vinniety's Avatar
Vinniety
Do you know how of course besides going to dealer?
Old May 13, 2012 | 10:21 PM
aljodoro's Avatar
aljodoro
Default TPMS Sensor replaced at Discount Tire
I just got a new TPMS sensor at Discount tire. when I was getting four tires put on. They told me it would not release pressure and should be replaced. They ordered one and put it in the next for $60 plus tax. They had to reprogram the unit. Had a few issues getting everyihing set up but they were great. . They gave me a lot of conifence they knew what they were doing.
Old Jun 22, 2012 | 05:49 PM
MSGX470's Avatar
MSGX470
Definitely more trouble than it's worth, just one more reason for you to have to take your truck into the dealer. Take the light bulb for the TPMS warning out of the dash, problem solved, forever.
yomarci
Feb 4, 2019 07:05 AM
jkonquer
GX - 2nd Gen (2010-2023)
Sep 25, 2018 09:09 AM
Nelli
RX - 3rd Gen (2010-2015)
Nov 30, 2016 12:46 PM
gserep1
Apr 29, 2010 10:42 PM
pseconds
Feb 20, 2010 03:52 PM
