Navigation Help...please.....
Old Apr 4, 2006 | 08:10 PM
chendanny's Avatar
chendanny
Default Navigation Help...please.....
I just screwed up my navigation but accidentally hitting load "US-TAB" under LOAD menu.
Now the navigation appear to be inoperative and the is a message in both English and
Japanese, "Insert correct disk". Any one knows how to reset it ? Please help.
Old Apr 4, 2006 | 08:23 PM
lepoch's Avatar
lepoch
I think you are screwed unless you take it back to the dealer
Old Apr 4, 2006 | 09:24 PM
koolaidman's Avatar
koolaidman
koeo
move front passenger seat all the way fwd.
with screw driver remove 2 plastic screws
remove cover
ull see the nav dvd eject and reinstall. this should bring it back to what it was before. if not get back to me
Old Apr 5, 2006 | 05:35 AM
CVsIS250's Avatar
CVsIS250
I agree. Time for a trip to the dealer.
CV
Old Apr 5, 2006 | 11:44 AM
chendanny's Avatar
chendanny
Default Help
Originally Posted by koolaidman
koeo
remove cover
THIS WILL RESET THE SYSTEM??????
Old Apr 5, 2006 | 09:23 PM
koolaidman's Avatar
koolaidman
it should do the trick
Old Apr 5, 2006 | 11:59 PM
chendanny's Avatar
chendanny
it didn't work......
do you have any suggestion?
Old Apr 7, 2006 | 06:45 PM
koolaidman's Avatar
koolaidman
if u can still use the display press
disp
top left corner
bottom lect cover
keep repeating until the diag screen comes up. wiat till it gets filled out
tell me what errors come up
Old Apr 7, 2006 | 07:23 PM
rklages's Avatar
rklages
not sure if this would help, but if you unplug the plugs into the dvd player under the passenger seat, or remove the ground from the battery for that matter, the nav will have to reload from scratch - not sure how much it remebers and how much it reloads, but worth a try.
Rob
Old Apr 9, 2006 | 01:05 AM
chendanny's Avatar
chendanny
disp
top left corner
bottom lect cover
it showed everything......but when i press navigation diagnostic screen.....a long beeping sound and that's it.. that's the end of it... so what's next??
Old Apr 10, 2006 | 06:50 AM
CVsIS250's Avatar
CVsIS250
drive to the dealer.
Old Apr 11, 2006 | 08:52 AM
chendanny's Avatar
chendanny
everything showed ok except the navi...showed "econ"
Old Apr 20, 2006 | 11:50 PM
chendanny's Avatar
chendanny
Default I Fixed It
I FIXED THE UNIT FINALLY. IT'S EASY AND SIMPLE.
Old Apr 21, 2006 | 05:15 AM
JWS3's Avatar
JWS3
Default SO-----how did you fix it?
How'd ya do it??
Old Apr 30, 2006 | 08:42 PM
davidfi01's Avatar
davidfi01
Can you please post your fix ...
thanks,
D
