LED Break Lights
Old Dec 14, 2005 | 11:05 PM
Kash's Avatar
Kash
Default LED Break Lights
hey, the 4 runner people on the 06's have LED Breaklights.. i was out and about and i saw one and i was like whohh thoes look nice and i've allways wanted led breaklights on the gx
so they have a thread.. http://www.toyota-4runner.org/showth...threadid=14083
i was wondering does anyone know if they can be modified to i guess fit in our housings because i doubt theirs would fit in ours
just worth a shot
and has anyone changed their license plate lights to led's?
Old Dec 15, 2005 | 06:03 AM
lonewolf69's Avatar
lonewolf69
Hi Kash,
What's the benifits of performing this switch? Is there that much of a difference when they're turned on, because they look the same when turned off...?
Old Dec 16, 2005 | 08:08 AM
Kash's Avatar
Kash
Originally Posted by lonewolf69
Hi Kash,
your break lights light faster, they look cooler imo
Old Dec 16, 2005 | 08:16 AM
The G Man's Avatar
The G Man
They turn on faster? Maybe a 1/4 of a second faster, not a big deal. In my opinion, they dont look better, maybe just looks different. One major benefit is that LED light use alot less energy and they last much longer than regular bulbs.
Old Dec 16, 2005 | 08:21 AM
lonewolf69's Avatar
lonewolf69
G-man,
I don't mean for this to sound sarcastic, but less energy? When engine is running all electrical components are drawing power from Alternator not battery so I'm not too sure why less energy would matter... ?
Now if you tell me I can get better GAS milege, I'll be all over that in a heartbeat!!!
-Alex
Old Dec 16, 2005 | 09:56 AM
The G Man's Avatar
The G Man
In a classic automotive charging system, there is a voltage regulator that controls the charging circuit and allows the alternator to charge the system. When a certain voltage is obtained, the regulator "opens" (or turns off) the circuit until the electrical system voltage drops, then it completes the circuit again. Therefore, if there is less of a electrical load on the system, there will be less of a load on the engine. Kind of like when the AC compressor turning on and off causing additional load on the engine. Remember, the electrical power in a car is not free energy, otherwise there would be no need for power plants, it is converting gas into electrical energy.
Would a LED tail light save gas due to less of a load on the engine, I dont think so. If it does, it would be so minimal that you would not even notice it. In my opinion, LED lights is the future, it draws less power and last much longer. There is even a LED headlight bulb in the works. A LED tail light might not make a big difference but a LED headlight would. The difference might be going from a 55 Watt bulb to a 10 or 15 watt LED bulb with the same light output, and the bulb will last the life of your vehicle.
Old Dec 16, 2005 | 10:12 AM
lonewolf69's Avatar
lonewolf69
Hi G,
Thanks for the explanation!
-Alex
Old Dec 16, 2005 | 04:04 PM
INHOCJP's Avatar
INHOCJP
LEDs definitely look nice.
Old Dec 16, 2005 | 05:42 PM
GS450h FTL's Avatar
GS450h FTL
Default I want them
LED look the best, I have always liked the way caddy's taillights come on.....
Old Dec 16, 2005 | 10:08 PM
tcesario's Avatar
tcesario
I know it doesn't seem like much, but 0.2 seconds faster (typical LED illumination time increase vs. Incandescent) is about 17 feet at 65 mph. Might be significant enough for the guy behind you if you have a freeway panic stop.
-Tony
Old Dec 17, 2005 | 12:41 PM
BobsGX's Avatar
BobsGX
-Tony
This is true but the GX already has the 3rd brake light which is LED.
Old Dec 17, 2005 | 03:54 PM
The G Man's Avatar
The G Man
The Caddy's taillight are some of the best in any car, it has that one piece look. I really dont like the LED light that looks like its made from bunch of small LEDs, even though they are all made that way.
Old Dec 17, 2005 | 04:39 PM
tcesario's Avatar
tcesario
That wasn't the point I was responding to. It was that the "minor" increased illumination speed of an LED wasn't important, when it fact it is significant in terms of braking distance.
-Tony
Gidovs
Oct 26, 2013 02:53 PM
horent135
VIP Style
34
Feb 27, 2012 11:19 PM
BRIANxJDM
Feb 23, 2011 11:42 PM
fud
Jan 17, 2011 12:50 PM
mwbuck
Lighting
12
Feb 3, 2007 10:23 AM
