change fuel filter- how often?
Old Mar 16, 2008 | 08:14 AM
jbw's Avatar
jbw
Default change fuel filter- how often?
I bought car with 42K miles and now have 67K. Should I have changed and if so, about how much should I be prepared to pay at Lexus/Toyota?
Old Mar 16, 2008 | 08:25 AM
RX729's Avatar
RX729
Replace it every 40k miles...
Old Mar 16, 2008 | 10:34 AM
SorrGwa's Avatar
SorrGwa
is there a write up for this? i remember when i purchased my gs300, and went to the dealership looking to buy the fuel filter, they said it had none. well specifically, there was a small filter on the fuel pump. is this the fuel filter?
if not, if there a picture somewhere of where the fuel filter is? =/ thanx
Old Mar 16, 2008 | 10:38 AM
FrankT's Avatar
FrankT
RX729- where did you get that info, maybe from the pimple face kid at autozone?
Toyota/ Lexus have no interval on fuel filters.
In general it is a lifetime filter.
It is good however to replace the filter when major work is done to the fuel system, new injectors, new fuel pump, head work, a new motor or maybe 250,000 miles on the original.
Old Mar 16, 2008 | 10:41 AM
jbw's Avatar
jbw
I doubt it was ever replaced based on other maintenance items that were ignored.
What will the dealer's charge? Will I save quite a bit by having my independent mechanic do or is it tricky?
Old Mar 16, 2008 | 10:47 AM
JeffTsai's Avatar
JeffTsai
It's not hard. It looks like a sock thing that goes over the bottom of the fuel pump.
Steps to replace:
-Remove rear lower seat section
-Remove 3 plastic nuts holding outer cover
-Remove screws holding in fuel pump assembly
-Disconnect fuel line and harness on top
-Pull out fuel pump assembly
-Remove fuel pump filter and replace with new
-Put everything back
I can do it in about 10 minutes.
Old Mar 18, 2008 | 11:01 AM
jamodeo's Avatar
jamodeo
If you would not mind..... Could you take pictures of this (anybody) if you attempt. I would like to do this, but I always love having a visual guide to aid me along
thank you -Joe
Old Mar 18, 2008 | 11:07 AM
kit cat's Avatar
kit cat
thank you -Joe
plus one since that free online manual is still down.
Old Apr 11, 2008 | 05:12 PM
PushinLEX's Avatar
PushinLEX
so wat does lexus say about this. change or not?
Old Apr 14, 2008 | 05:40 AM
Rock-a-Lex's Avatar
Rock-a-Lex
+1...that's what I'd like to know. I have almost 100K on my car and I noticed that my gas mileage has been terrible for the past year or so. I tried everything BTW...
Old Apr 14, 2008 | 05:48 AM
Dslexic's Avatar
Dslexic
CL Folding 10,000
If I'm not mistaken a fuel filter normally resides within the engine bay and kind of resembles a pop can that maybe black in color. The filter that is directly connected to the fuel pump is the fuel pump strainer which is not as efficient as an actual filter. So in essense the GS might not have an actual fuel filter.
Old Apr 14, 2008 | 06:39 AM
Debonair's Avatar
Debonair
I think the last cars I worked on (I don't work on many anymore) that had a under hood filter were Honda's. Most vehicles now have them mounted along the framerail. Others like my Durango and GS430 have then incorporated into the fuel pump. The manufacturers usually say that the fuel pump mounter fuel filter is good for the life of the pump so no service interval is given.
Se GS Fuel pump exploded view below.
3UZFTE's Avatar
3UZFTE
No, Jefftsai is right. It is in the fuel tank, on the fuel pump. Toyota claims that the filter will last the life of the pump, which they claim should last the life of the vehicle.
Old Apr 14, 2008 | 07:59 AM
FrankT's Avatar
FrankT
nice diagram...
Old Apr 14, 2008 | 10:04 AM
lexusondubs's Avatar
lexusondubs
dubsonlexus
liftime filter no need to change according to lexus soo why are you changing it anyways ??
