Hi. Will the following spec wheels clear the calipers on the GSF? The widths are a bit smaller than factory, which is what makes me unsure about the specs on the offsets. I would rather avoid spacers. Thanks. Wheels are Rays G25's.
__________________ 1440 E Cedars St.
Ontario, CA 91761 WEEKLY specials PM me Web:www.ModInJapan.com Email: info@modinjapan.com Toll Free: 866 599-5227 Local: 909 259-5117 Quick Quotes and Stock Checks, Send us a Text Message!
Text Here: 1-657-229-0050
Seems both your wheels are .5 less in diameter form stock wheels.
I'm curious as to what size tires would fit on those wheels? Are you planning to use the OEM tires (255/35/19 & 275/35/19) ?
No, they are ½" less in the width. Diameter is the same @ 19". Stock 255/35/19, 275/35/19 tires will fit the smaller width. But, that is a move I personally would not make.
Lou
Just curious what the issue would be if going down half inch in width ?
^^^^Less volume for holding air, so less load carrying capacity. If, in the future you decide to upsize your tire size, you're outa luck. Also, to a small extent, handling may be impacted by the 5% change in wheel width.
Thanks Lou. Yeah I saw the same on the Rays site after I posted this. There's a set for sale on Facebook marketplace, but I wasn't sure about the offsets and 1/2" narrower width. It would have been a good deal, but I'd rather not go down in width after reading up on the effects.
