2016 gsf wont move
Old Nov 3, 2024 | 02:22 PM
diegoh510's Avatar
diegoh510
2nd gear
Default 2016 gsf wont move
Hello everyone posting here in regards of my Lexus gsf with 116k miles just to says that on two days ago I did a quick pull and I heard something loud from the rear or popped it didn't move anymore no engine light or nothing. I was near my house so I just parked it back in neutral and moved it. But every time I would try and drive it it would feel like I'm driving over a rock or something from the rear I checked the area no leaks or broken axle Does anybody have some type of idea what it could be. Thnx in advanced I was thinking of towing it to Lexus but I'm afraid it'll be something a lot worse
Old Nov 3, 2024 | 06:25 PM
cyfi66's Avatar
cyfi66
Hmm, there was a report of a rear end failure earlier this year. Pull the drain plug and check the fluid condition.
https://www.clublexus.com/forums/gs-...d-goodbye.html
Old Nov 3, 2024 | 10:11 PM
NotnFsport's Avatar
NotnFsport
like the above person said..pull your diff drain plug and see what comes out. I had a very similar issue and my diff decided to shear it's gears
Old Nov 4, 2024 | 05:33 PM
diegoh510's Avatar
diegoh510
2nd gear
Thank you 🙌🏽
Old Nov 5, 2024 | 12:31 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
This is starting to make me nervous. I serviced the wife's car in the last 10k miles - diff and TVD clutches. I'll be mightily pissed off if the ring gear fails. That's not at all expected. Components like this typically have at least a 500,000 mile service life.
Old Nov 5, 2024 | 04:00 PM
FCarDriver's Avatar
FCarDriver
8th Gear
What is the change interval miles/time on the diff and clutches? Thanks!
Old Nov 5, 2024 | 06:15 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
The US model does not have a change interval specified. Sad but true, the EPA has made this a reality. The manufacturers do not want to deal with the waste streams, so they call everything but engine oil and coolant a "lifetime" fill, even though they know a lot better and specify change intervals in other markets.
I did the wife's car at about 120k miles.
Old Nov 5, 2024 | 11:37 PM
designo's Avatar
designo
The dealer here in Bahrain replaces my diff fluid every 40k kilometeres. Around 25k miles.
Old Nov 8, 2024 | 11:56 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
I did some more homework on this problem today. There is a complete parts breakdown (except the TVD clutches themselves), and the parts are common to a range of Lexus vehicles including the IS F. This means setting up the TVD's conventional section isn't magic at all, and parts are available. It should be possible to repair this kind of damage for less than $1k in parts. Keep in mind, there is nothing salvageable except the housing itself, and likely the snap rings used to set preload on the side bearings. Anything else will be at the very least suspect, and IMHO, the gearset and all the bearings are garbage once the metal shards have got into the oil. The only tricky part is there is no guidance on attaching the TVD clutches to the main drive housing - no torque specs, procedures, or guidance for how to do this right. On the upside, the parts breakdown doesn't show axle retention clips, so that dramatically simplifies installing the TVD clutches; no need to hammer in the units like a regular axle. I doubt there's any magic since these things should be easy to build, but it would really suck to go through the whole rebuild process and have something with the TVD clutch installations spoil the whole thing.
roblim
Jan 31, 2017 07:45 PM
Ramon
Nov 18, 2007 09:41 PM
JonCAGS300
GS - 1st Gen (1993-1997)
Nov 27, 2006 07:10 PM
Luv Da Lex
Jul 11, 2006 08:24 PM
Lexson
Sep 6, 2002 12:43 AM
