Do All 4GS Models Use The Exact Same Front Caliper?
Old Mar 4, 2020 | 11:32 AM
  #76
bclexus's Avatar
bclexus
Originally Posted by BMGS
I have the 13.1" rotors and looking at the clearances, I cant see any way I could just throw on the 14" rotor, everything else left the same. There must be some other difference between the two setups.
A quick anecdote has me thinking this. On my last car I did a custom install of an 8 piston AMG caliper with a 15.4" rotor. On the mid-2000's AMG setups, the V8 vehicles use a 360mm (14.1") rotor and the v12 vehicles use a 390mm (15.4") rotor. Both use the same caliper but there is a mild difference on the caliper mounting bracket which pushes the caliper outboard a bit to accommodate the larger rotor.
I too thought this would be the case with the Lexus GS 350 when I learned that the same 4-piston brake caliper is used on all RWD models - that there would be a difference in the mounting location of the brake caliper on the steering spindle knuckle - one caliper mounting position for the F-Sport RWD for the 14.0 inch brake rotor and another different caliper mounting position for the non-F-Sport RWD using the 13.1 inch brake rotor. But, that is not the case! I can find only one set (LH & RH) of steering spindle knuckles for the GS 350 RWD regardless whether the model is a F-Sport RWD or a non-F-Sport RWD. There is a different set (LH & RH) of steering spindle knuckles for the GS 350 AWD due to the live front axle of the all-wheel-drive.
Part #43202-30040 LH/Drivers Side Steering Spindle Knuckle - for ALL GS 350 RWD models (GRL10)
Part #43201-30030 RH/Passenger Side Steering Spindle Knuckle - for ALL GS 350 RWD models (GRL10)
Part #43202-30050 LH/Drivers Side Steering Spindle Knuckle - for GS 350 AWD models (GRL15)
Part #43201-30040 RH/Passenger Side Steering Spindle Knuckle - for GS 350 AWD models (GRL15)
Please search with any Lexus parts website you wish. Here's one ► Lexus Parts Now.com
Search for part number or keywords: 'Front Steering Knuckle'
Vehicle: 201* GS 350 or enter a VIN
See if your search results are the same as mine:
Old Mar 4, 2020 | 01:27 PM
  #77
bclexus's Avatar
bclexus
Originally Posted by peasodos
That's what I have been saying since the beginning of this thread, only difference is the mounting bracket/points for the caliper(probably on the caliper itself), but BC keeps going on and on with his investigation, blah, blah, blah lol
Also the inner diameter of the f-sport rotor being larger so the rotor/pad contact area width is about the same, using the same exact size pads.
peasodos - My thoughts were [originally] the same as yours, but everything to prove that point has been nullified.
From what I can determine:
There is only one set (LH & RH) of brake calipers used for all GS 350 RWD models (F-Sport & non-F-Sport).
The brake calipers themselves only have one set of mounting holes.
The brake calipers are mounted directly to the steering spindle knuckles. There is no separate mounting bracket/points for the caliper, or on the caliper, as you suggest.
There is only one set (LH & RH) of steering spindle knuckles for all GS 350 RWD models.
Do you have any [other] ideas on how the GS 350 RWD brake caliper setup can accommodate both a 13.1 inch brake rotor and a 14.0 inch brake rotor?
In the meantime the answer to the mystery (a.k.a. investigation) continues!
Old Mar 4, 2020 | 07:10 PM
  #78
bclexus's Avatar
bclexus
Can anyone find a parts website that specifically states the part numbers below shown in blue are for the 14.0 inch rotors?
Lexus Part #47750-22460 LH Brake Caliper - 13.1 inch rotor
Lexus Part #47750-30560 LH Brake Caliper - ?
Lexus Part #47730-22460 RH Brake Caliper - 13.1 inch rotor
Lexus Part #47730-30560 RH Brake Caliper - ?
All the parts websites I have visited, looking for information, say that all four of the above brake calipers fit all models of the 4GS, both Base and F-Sport. I do not believe that is accurate!!!
Here is an example of what I keep seeing on the parts websites. The website says this brake caliper fits both the Base and F-Sport models.
I am beginning to think the brake calipers #44750-30560 & #47730-30560 are for the 14.0 inch rotor...and the websites saying these calipers are for both the Base and the F-Sport models are wrong.
Does anyone care to help confirm my belief?
Old Mar 4, 2020 | 07:44 PM
  #79
NebulaGrey's Avatar
NebulaGrey
Old Mar 5, 2020 | 08:48 AM
  #80
bclexus's Avatar
bclexus
On the Lexus Stevens Creek parts website look at 'Vehicle Fitment' and click on '23 more fitments' and you'll see that brake caliper part numbers 47750-30560 & 47730-30560 are shown to fit both the F-Sport and non-F-Sport models, not just the F-Sport model. That's what all the Lexus parts websites show, which I now believe to be wrong.
Old Mar 5, 2020 | 08:53 AM
  #81
chrispy's Avatar
chrispy
The F-Sport caliper that uses the 14" rotor is visually different from the non F-Sport caliper. You can tell it's a larger caliper just by looking at it. The non F-sport caliper is the same as 06-11 GS350 RWD and 06-13 IS350 RWD.
Old Mar 5, 2020 | 09:01 AM
  #82
bclexus's Avatar
bclexus
That's good to know. So, after chasing incorrect and misleading Lexus parts websites it's almost certain that the F-Sport does indeed use a different front brake caliper to accommodate the larger 14.0 inch brake rotor.
The answer to the question 'Do All 4GS Models Use The Exact Same Front Caliper?' should not have been such a mystery, but sadly it was because of incorrect Lexus parts websites.
Old Mar 5, 2020 | 09:38 AM
  #83
signdetres's Avatar
signdetres
Not just those, Lexus' own website too!
Old Mar 5, 2020 | 10:15 AM
  #84
baconRx's Avatar
baconRx
the brembo kit i have is the same rotor size for the front just bigger caliper. i never took the time to install the rear so if anyone is interested i'd part out with the kit
Old Mar 5, 2020 | 01:27 PM
  #85
bclexus's Avatar
bclexus
Sad, but true! Lexus' advertising materials are incorrect, and has been for years. Lexus' own parts information is incorrect, and has been for years.
It makes me wonder how many people order parts from Lexus parts websites, using the VIN to assure the parts fit, and receive parts that do not fit the vehicle because of Lexus' sloppiness.
Old Mar 10, 2020 | 12:44 PM
  #86
Mtandle's Avatar
Mtandle
Default Caliper fitment
I just went through this. The advics caliper only fits gs model with the smaller rotor. I have the f sport model with 14" rotors and the advics calipers do not fit!!! UOTE=bclexus;10740672]Do All 4GS Models Use The Exact Same Front Caliper? We may finally have the answer...
There seems to be confusion about the front calipers for the various GS 350 models, including the GS 450h. The confusion is whether the F-Sport RWD uses a different caliper than the other 4GS RWD models. Also, whether the Lexus marketing literature and website is correct that only the F-Sport RWD model uses 4-piston front calipers. The following information has been gathered in order to answer those questions!
Here is an ADVICS #47750-22460 OE Left Front 4-Piston Caliper off a GS 350 for reference
From what I can determine from ADVICS (brand name) Original Equipment Lexus Front Brake Calipers - these two (Left & Right) caliper part numbers are for all 4GS RWD models:
ADVICS A5L079 Lexus 47750-22460 Front Axle Left Caliper for: LEXUS GS (2011-) _L1_ - 3.5 350 GRL10_, GWL10_ [01.2012 - present]
ADVICS A5R079 Lexus 47730-22460 Front Axle Right Caliper for: LEXUS GS (2011-) _L1_ - 3.5 350 GRL10_, GWL10_ [01.2012 - present]
Note also that the 4GS front calipers are 4-piston calipers, not 2-piston calipers that we have seen on official Lexus literature, including the Lexus website.
The above front calipers are exactly the same for all RWD GS models. (Note: I believe the AWD models use a different front brake caliper that is required by the all-wheel drive system, but I am focusing more on the F-Sport RWD using 14 inch rotors versus the other RWD models using 13.1 inch rotors.)
The
following five different GS models were used to obtain information about calipers for 4GS RWD models. (Note: VIN numbers are for salvaged vehicles or vehicles currently for sale):
VIN# JTHBE1BL9E5029285 - 2014 Lexus GS 350 F-Sport Pkg RWD
VIN# JTHCE1BL4E5021003 - 2014 Lexus GS 350 F-Sport Pkg AWD
(I believe AWD models use a different front brake caliper that is required by the all-wheel drive system.)
VIN# JTHBE1BL0E5036318 - 2014 Lexus GS 350 Premium Pkg RWD
VIN# JTHCE1BL4E5020157 - 2014 Lexus GS 350 Premium Pkg AWD (I believe AWD models use a different front brake caliper that is required by the all-wheel drive system.)
VIN# JTHBS1BL8HA002129 - 2017 Lexus GS 450h F-Sport Pkg RWD
__________________
While the 4-piston front brake calipers are the same for all 4GS models with RWD the F-Sport RWD model appears to use a different Toyota brand brake pad that has a slightly different dimension of the composition material to accommodate the 0.45" larger surface area of the 14 inch rotor as compared to the 13.1 inch rotor.
Note: When looking at the Akebono and EBC application recommendation both company's websites list the same brake pad for all 4GS RWD models with no distinction for the F-Sport RWD with the larger 14 inch rotor. It remains to be seen whether this is accurate, or not. [/QUOTE]
Old Feb 8, 2021 | 05:30 AM
  #87
GRL10Pilot's Avatar
GRL10Pilot
That's correct - #04465-30470 has been replaced with #04465-30510. I wish I knew why the replacement was made, who made the replacement (Toyota/Lexus or the pad maker), and what the difference is between the two brake pads. Three questions we'll probably never know the answers to.
Apparently 04465-30510 is still being made by Advics.
Also it is compatible for 3GS too.
Even the codes in the pad "477-S19" "PV565H-FG" are still same.
Old Jun 26, 2021 | 05:25 AM
  #88
mfaheem's Avatar
mfaheem
Guys, I need urgent help. Yesterday I cross threaded the caliper and the mounting bolt for the front RH passenger side for a 2013 GS 350 Lux Package Non Fsport.
Does anyone knw who I can interchange the part with ? Do the 2016/2017 IS 350 use the same calipers or even RWD non F sport GS 350? There are many for sale in the junkyard.
Old Feb 7, 2022 | 06:26 PM
  #89
bmwjavier's Avatar
bmwjavier
hi,
Definitely all 4GS models use the exact same front caliper or not? I have 2013 Gs450h Luxury and my rotors are 14 inch. (I assume the previous owner would replace the brakes with the F-sport ones.).....
Textar pads references are: TEXTAR 2032501 for non sports models and TEXTAR 2496501 for Sport models.....
TEXTAR 2032501 heigh is 77,3 and TEXTAR 2496501 is 78,5......
And here my car with Jurid Rotors 562949JC-1 rotor(Jurid says that 562949JC-1 rotor is compatible with LEXUS (43512-30371), but Jurid 562949JC-1 is 13,1 inch and Lexus 43512-30371 is 14 inch, which makes me think that the sport version (14" rotor) could have the same caliper as the non-sport version (13.1" Rotor)....
My mechanic told me that he didn't mount the rotor for me because being 13.1" it wasn't compatible with my car (14"), but if the caliper of the 14" sport models is the same as that of the 13.1" non-sport models then maybe he could install it, right?
And here my 14" Rotors:
Old Feb 8, 2022 | 12:46 AM
  #90
peasodos's Avatar
peasodos
Originally Posted by bmwjavier
hi,
The caliper could look exactly the same, but the mounting holes could be in a slightly different position between 13.1" and 14" rotors.
