Radiators
Old Nov 19, 2020 | 11:01 AM
dumanzio's Avatar
dumanzio
Default Radiators
I have a 2013 GS-350 F-sport with just ovr 80,000 miles. The manuel does not suggest anuthing about the radiator but curious if I need to concern myseld with proactive flushing and radiator fluid flushing?
Old Nov 19, 2020 | 01:11 PM
Cwang's Avatar
Cwang
150000 km/90000-100000 miles is when you change the coolant.
Old Nov 19, 2020 | 03:13 PM
2GR's Avatar
2GR
Is there a bleeder screw or burp valve on these engines?
The standard toyota v6 has one, but don't see on the Lexus engine.
Old Nov 20, 2020 | 01:10 AM
Cwang's Avatar
Cwang
I'll let you know, if my children allow me any free time tonight!
Old Nov 20, 2020 | 04:01 AM
richard203's Avatar
richard203
theres two bleeder valve in the engine but i dont know where it located.
Old Nov 21, 2020 | 02:26 AM
Cwang's Avatar
Cwang
According to this, there is no bleed screw. It seems to be somewhat automatic, just need to rev the engine and squeeze the pipes
ADD ENGINE COOLANT
a. Tighten the radiator drain **** plug by hand.
b. Tighten the 2 cylinder block drain **** plugs.
Torque:
13 N*m{ 130 kgf*cm , 9 ft.*lbf }
c. Add TOYOTA Super Long Life Coolant (SLLC) to the water outlet sub-assembly
opening.
Standard Capacity:
Item Specified
Condition w/o
Transmission Oil
Cooler 9.7 liters (10.3
US qts, 8.5 Imp.
qts) w/ Transmission
Oil Cooler 10.0 liters (10.6
US qts, 8.8 Imp.
qts) HINT:
TOYOTA vehicles are filled with TOYOTA SLLC at the factory. In order to avoid
damage to the engine cooling system and other technical problems, only use
TOYOTA SLLC or similar high quality ethylene glycol based non-silicate, nonamine, non-nitrite, non-borate coolant with long-life hybrid organic acid
technology (coolant with long-life hybrid organic acid technology is a combination
of low phosphates and organic acids).
d. Slowly pour coolant into the radiator reservoir tank until it reaches the full line.
e. Press the No. 1 and No. 2 radiator hoses several times by hand, and then check
the level of the coolant.
If the coolant level is low, add coolant.
f. Install the radiator cap.
g. Bleed air from the cooling system.
NOTICE:
Before starting the engine to warm up the engine, turn the A/C switch off.
i. Warm up the engine until the thermostat opens. While the thermostat is
open, circulate the coolant for several minutes.
CAUTION:
When pressing the radiator hoses:
• Wear protective gloves.
• Be careful as the radiator hoses are hot.
• Keep your hands away from the radiator fans.
HINT:
The thermostat open timing can be confirmed by pressing the No. 1
radiator hose by hand, and checking when the engine coolant starts to
flow inside the hose.
ii. Maintain the engine speed at 2000 to 2500 rpm.
iii. Press the No. 1 and No. 2 radiator hoses several times by hand to bleed
air.
CAUTION:
h. Stop the engine, and wait until the engine coolant cools down to ambient
temperature.
CAUTION:
Do not remove the radiator cap while the engine and radiator are still hot.
Pressurized, hot engine coolant and steam may be released and cause serious
burns.
i. Check the coolant level in the radiator reservoir tank.
If the coolant level is low, add SLLC to the radiator reservoir tank full line.
Old Nov 21, 2020 | 02:50 PM
richard203's Avatar
richard203
I guess im wrong lol. i thought cylinder block drain **** plugs was the bleeder valve lol.
Old Nov 22, 2020 | 01:15 PM
Cwang's Avatar
Cwang
Can somebody explain what I posted? Is there a special valve that only allows air to pass when you squeeze the radiator pipes?
Old Nov 22, 2020 | 04:02 PM
richard203's Avatar
richard203
from the instruction look like if you loosen the cylinder block drain **** plug it just let more coolant out and then you tighten it back when you pour new coolant in. you missed the part where it say drain coolant mybe thats why u got confused on the part when you tighten the cylinder block drain **** plug when adding coolant instruction.
Old Nov 22, 2020 | 05:36 PM
2GR's Avatar
2GR
Interesting...most cars I've worked on have some kind of bleeder screw/valve.
I hope it's an easy engine to burp. One small bubble can cause a big headache.
sm1ke
Nov 20, 2020 07:19 AM
RI-Lex
14
Aug 10, 2020 04:28 PM
NLLex
Jun 3, 2020 02:30 PM
chaiyang7
Sep 24, 2012 01:00 PM
MrCJ305
May 25, 2012 03:07 PM
