gs300h intermittent starting problems
Old Jul 1, 2020 | 08:34 AM
Sligotrev's Avatar
Sligotrev
Default gs300h intermittent starting problems
Hi everyone.
Greetings from Ireland.
I have an intermittent (and annoying) problem with my 2017 GS300H. Sometimes, randomly, when I try to start up to move away, all dashboard light illuminate but the car will not move.
It sometimes takes 8-10 attempts to get it to start-up, by switching the on/off button until it eventually starts up and moves away.
doesent happen every time, just now & again.
can anyone please advise as to the problem?
thanks.
Old Jul 1, 2020 | 09:02 PM
Cwang's Avatar
Cwang
I'm assuming you're having trouble when it's running off battery and not engine? You may want to post in the Hybrid part of the forum, we don't understand such black magic!
Old Jul 2, 2020 | 12:01 AM
Sligotrev's Avatar
Sligotrev
Hi there,
thanks for replying; yes I do think the problem arises when the car is trying to start from battery.
I will post in hybrid section and see if anyone can help, thanks.
Old Jul 2, 2020 | 09:20 AM
websurfer's Avatar
websurfer
When was the battery last changed?
Old Jul 2, 2020 | 10:47 AM
er34's Avatar
er34
You do realize despite it being a hybrid, the car still has a 12v battery that will age and needs to be replaced right?
Old Jul 2, 2020 | 04:03 PM
Sligotrev's Avatar
Sligotrev
Hi there,
Thanks for the replies; the hybrid battery was never changed, I didnt think it would need to be changed yet as the car is only 3 years old.
The 12v engine battery seems fine; again i dont think thats the problem either as the starting problem only happens now & again- if it were the 12v battery it would not work at all, right?
I also changed both keyfob batteries recently but that didnt solve the problem..
Old Jul 2, 2020 | 04:35 PM
Im2bz2p345's Avatar
Im2bz2p345
There is a 12V battery in your trunk, on the left side under the trunk mat/liner. While that 12V trunk battery is not what starts your vehicle, it is an auxiliary battery the provides power to the hybrid system/ECU/other electric components in your vehicle. I would get that battery load tested as a first step.
If the 12V battery is experiencing drainage, it could be the Network Gateway ECU. Here is the TSB on it: https://static.nhtsa.gov/odi/tsbs/20...86305-5448.pdf
Some other relevant topics on it:
https://www.clublexus.com/forums/gs-...50-2013-a.html
https://www.clublexus.com/forums/gs-...ery-drain.html
Not sure what else could it could be because this the first that I've read about the hybrid experiencing this. Please do share when you figure it out though!
Hope that helps somewhat,
~ Im2bz2p345
Edit - Oops, just read you're from Ireland. Some of my post might not apply, but good to look into the 12V auxiliary battery in your trunk.
Old Jul 2, 2020 | 05:00 PM
peasodos's Avatar
peasodos
You need to change the 12v battery in the trunk. It’s dying off and that’s why you are having these issues. Nothing wrong with the hybrid battery. My 12v battery failed after almost 7 years. In the USA it’s located on the driver side of trunk, just lift up floor panel cover.
Old Jul 4, 2020 | 02:11 PM
703's Avatar
703
Just test the 12v first. No need to speculate what is wrong.
Old Jul 5, 2020 | 02:58 PM
Sligotrev's Avatar
Sligotrev
Hi there,
Thanks for the advice everyone; I will have a look at the 12v battery in boot/trunk and get it tested to see how its holding up.
much appreciated,
Trevor.
Old Jul 6, 2020 | 03:13 AM
Cwang's Avatar
Cwang
Originally Posted by Sligotrev
Hi there,
much appreciated,
Trevor.
If it's more than 4 or 5 years old I'd just change it anyways. These cars are too reliable to be brought down by an old battery
shn7926
Jun 21, 2011 07:35 PM
hadeed350
Aug 8, 2007 01:17 PM
ES350Bob
21
Oct 27, 2006 09:46 AM
soarer129
Maintenance
May 18, 2006 01:55 PM
