Window sticker warning for maintainence
Old May 24, 2020 | 12:08 PM
websurfer's Avatar
websurfer
Default Window sticker warning for maintainence
I was at the local Lexus dealer and noticed this sticker on a 2020 GS350 F sport RWD.
Is that what everyone is getting in terms of mileages for the tires, brakes and rotors for these vehicles?
Old May 24, 2020 | 12:32 PM
chinee's Avatar
chinee
That's a GSF not an F Sport... at least that's the pic on the sticker.
But a lot of manufacturers use disclosures like those, so buyers can make a more informed decision, knowing that brakes and tires don't last long on high performance cars.
Old May 24, 2020 | 12:54 PM
websurfer's Avatar
websurfer
It's a GS350 F sport. I was at the dealer test driving it.
Old May 24, 2020 | 03:32 PM
BMGS's Avatar
BMGS
Lol at inherent brake squeal, that's just the service dept. being lazy. I have run 2, 4, 6 and 8 piston Brembo calipers on a variety of vehicles and I have never encountered squeal was not remedied by either bedding, a different formula pad or a new proper application of high quality brake lube.
It's not always fun or cheap to swap out sets of pads or rotors but it shouldn't be accepted that a high performance brake setup squeals just because it's high performance. Lexus is not the only mfg. who will try to convince customers that falsehood.
Old May 24, 2020 | 05:58 PM
AJLex19's Avatar
AJLex19
That is standard language used for the RWD F-Sport. It is labeled in the brochure in fine print. They are just bringing it to people's attention because i'm sure many customers have complained about the the tread wear / life of both the tires and brakes/rotors. Also, many owners have complained about the the RWD F-Sport brake squeal due to the two-piece rotor design.
Essentially, if these are things that bother you, maybe stay away from a RWD F Sport b/c its in the fine print (they just did customers a favor by adding it to the door jam). Once you buy it, don't expect there is anything "wrong" with your car.
Highlighted in the fine print of the brochure:
Old May 24, 2020 | 06:29 PM
websurfer's Avatar
websurfer
It's great for them to post that but I'm sure it surely scared off many people from purchasing.
Old May 25, 2020 | 08:05 AM
CottageChz's Avatar
CottageChz
They had the tire warning sticker on the AWDs at my local dealer. I think the mileage was a little higher than 15k, maybe 25k? First time I’d seen a sticker like that.
Old May 25, 2020 | 09:25 AM
websurfer's Avatar
websurfer
Given that all GS including the GS350 will end production. Will parts be hard to find?
Old May 25, 2020 | 09:30 AM
mcomer's Avatar
mcomer
Our 2010 HS250h had the disclaimer sticker that the tire wear would be < 25K miles.
When we turned in the 48 month lease with 33K miles the tires enough tread left that
when the dealer sold it Certified without changing the tires!
This anecdotal example is not a case of performance oriented tires however. The
tires fitted to the HS's were a unicorn size, 225/45WR18 that only Toyo seems to
make. Designated as Low Rolling Resistance (Hybrid car, right?) but also low profile.
Not great handling tires, rode harshly and didn't do well in snow or even rain! Other
than that...good tire wear. Wished they would have worn out but nearly zero alternatives
at least back in 2013.
Rexiah
LX - 3rd Gen (2008-2021)
20
Aug 13, 2016 12:00 AM
KJD3
GS F (2016-present)
Jan 13, 2016 04:01 PM
PCB Lexus
Sep 14, 2010 07:57 AM
Brewdog
RX - 3rd Gen (2010-2015)
Oct 28, 2009 01:11 PM
idsrvit
Maintenance
Nov 29, 2004 02:59 PM
