2016 bumper off -parking light wire help!
Old Feb 15, 2020 | 09:43 AM
SharpGent's Avatar
SharpGent
Default 2016 bumper off -parking light wire help!
I am installing fogs amd have decided not to mess with the oem switch. I'm going to tap the parking light wire. Rather than run into the cabin, I figured I would just tap AT the light. Which wire is the positive?
I have a voltmeter, but don't know how to test with this connector. This is behind the passenger side (under headlight)
Please help!
Old Feb 15, 2020 | 10:03 AM
SharpGent's Avatar
SharpGent
It's a green wire under the dash... so could it be one of these two green ones? This plug looks to control everything inside the light assembly, so it has to be one of these, right?
Old Feb 15, 2020 | 10:41 AM
SharpGent's Avatar
SharpGent
I used a volt meter after disconnecting the harness and tested all of them. The black wire looked like it had power, but after test-tapping I dont think it has enough juice.
Anyone have another idea where to tap the parking wire under the hood?
Old Feb 15, 2020 | 01:04 PM
peasodos's Avatar
peasodos
Why not wire up a relay with the trigger being the parking lights or drl and the power connected to the 12v battery. That way the fogs turn on whenever the trigger is hit and gets power from the battery. Don't forget to fuse it so you don't damage anything.
Old Feb 15, 2020 | 04:04 PM
SharpGent's Avatar
SharpGent
That's exactly what I'm doing. I'm looking for the power to the parking lights to trigger the relay. I couldn't find it after testing, so I just replaced the goddamn washer reservoir (no amount of manipulating it would give the lights clearance) and ran the trigger into the cabin. I tested the lights with the battery (power trigger from positive, trip relay, lights on) and they are everything I wanted. The light output isn't great, but they look amazing. I'll finish wiring the trigger under the dash in the morning. It's time to shower and head to dinner.
Also, could you remind me which wire / where for parking lights? Green wire, N12 connector?
Old Feb 15, 2020 | 04:09 PM
SharpGent's Avatar
SharpGent
With the parking lights on, this is exactly what I wanted. It was a long endeavor to do this project (Nigel's kit came with a wire harness that didn't work so I had to run new wires myself - and the washer bottle DEFINITELY needed to be replaced) but I am happy with the lights.
Old Feb 15, 2020 | 06:18 PM
peasodos's Avatar
peasodos
Man that looks sick, so your fogs are always on, unless you turn off your drl?
Old Feb 15, 2020 | 07:46 PM
SharpGent's Avatar
SharpGent
Actually, during this photo, the trigger wire is clipped to the battery for testing. When I run it into the cabin tomorrow morning, I will tap into the parking light wire. So when then parking or headlights are on they'll turn on.
I have a few minor scratches from the whole bumper fiasco, so tomorrow I'm removing those and then I'll grab some better photos. I just need to vinyl the roof and spoiler and I'm done.
Old Feb 15, 2020 | 08:54 PM
AJLex19's Avatar
AJLex19
@SharpGent looks great! Well done
macjac69
Aug 23, 2014 11:10 AM
mauibuilt1
Sep 21, 2011 09:08 PM
suprahtt
Dec 1, 2007 07:56 AM
hemogoblin
Nov 29, 2007 05:36 AM
datsetup
Nov 26, 2005 11:43 PM
