Work Wheel Offset Help
Old Feb 3, 2020 | 02:44 PM
D1GP's Avatar
D1GP
Default Work Wheel Offset Help
Hi all - I recently purchase a set of Work Zistance wheels with the offset of
F: 20 x 9.5 +33 S-Disk (standard disk)
R: 20 x 10.5 +30 W-Disk (deep disk)
Unfortunately, this offset is slightly more aggressive than I wanted.
I am planning on ordering another set and was wondering if anyone can help confirm that this will fit in our GS
F: 20 x 9.5 +46 S-Disk
R: 20 x 10.5 +42 W-Disk
Thanks!
Old Feb 3, 2020 | 03:13 PM
jdpdata's Avatar
jdpdata
You're not going to get a lot of responses here about wheel offset. Nobody knows anything about it or cares.
Your best bet is call the place where you're purchasing from and ask them which is proper fitment for what you're trying to do and the look you're after.
To reference, these are my wheel offset for my Weds Mav 709M which are very similiar to your Work Zistance. Albeit, I didn't go as wide as I didn't want to do any major fender work on mine. With 9.5 F and 10.5 R you will have to roll or shave your fender liner. Mine is already having minor rub when I hit a dip or carry heavy passengers...thank goodness my kids are still small and I rarely carry adult passengers.
F: 20 X 9 +37 H-Disk Reverse Rim
R: 20 x 10 +42 L-Disk Reverse Rim
Old Feb 3, 2020 | 05:47 PM
D1GP's Avatar
D1GP
Appreciate the reply. What about tire size? What did you go with for your setup?
kietlander's Avatar
kietlander
the front offset looks a bit high, not sure if you will have enough inner clearance and or brake clearance issues.
Old Feb 3, 2020 | 06:02 PM
jdpdata's Avatar
jdpdata
Michelin A/S3+
F: 245/35ZR20
R: 275/30ZR20
Old Feb 3, 2020 | 06:35 PM
mikesd1980's Avatar
mikesd1980
I have AWD with 20x9 et38 R 20x10.5 et45 R. I installed camber arms also. I was going through rear tires every 2 months before install...
Old Feb 3, 2020 | 08:16 PM
veez81's Avatar
veez81
I have 20x9 +32 R-disk and 20x10.5 +45 A-disk. 245/35/20 and 285/30/20. fronts rub slightly if I hit a dip too hard. Got my rear fenders rolled to fit 285/30
Old Feb 4, 2020 | 12:19 AM
DuB's Avatar
DuB
Hey D1GP, I think I met you at Platinum VIP the other night, there can't be another person with a set of Zistance with the same specs haha.
My wheel's specs are:
Work Zeast 2
20x8.5 +35 R-Disk
20x10 +40 H-disk
Pilot Sport 4S
245/35 20
275/30 20
Aired out, I rub in the front on dips on the freeway, and making left turns through intersection into dips. I think it's mostly the square tires though. I originally wasn't planning on cups or going that low.
I've attached a spreadsheet I made to calculate wheel specs to see how each setup compared to each other. The current specs in there were collected from threads where people said they got the setup to work, so it's labeled "works". Your Zistance set is highlighted in green. My current wheels are highlighted in yellow.
Old Feb 4, 2020 | 10:06 PM
veez81's Avatar
veez81
Originally Posted by jdpdata
Michelin A/S3+
F: 245/35ZR20
R: 275/30ZR20
what are you dropped on?
Old Feb 4, 2020 | 10:34 PM
jdpdata's Avatar
jdpdata
RSR active Besti coilovers. Fully compatible with AVS.
Old Feb 4, 2020 | 11:07 PM
veez81's Avatar
veez81
man, that looks so good.
Old Feb 5, 2020 | 09:23 PM
terrycs's Avatar
terrycs
If you are planning to lower your car too, you can refer to the database here:
https://www.clublexus.com/forums/gs-...els-tires.html
Thanks!
Old Feb 5, 2020 | 10:26 PM
DuB's Avatar
DuB
That database is awesome, thanks for putting that together! It was so helpful!
Automan
Wheels, Tires & Brakes Forum
Mar 11, 2010 11:15 AM
AK-47
Mar 17, 2008 01:04 PM
DawgMode
GS - 1st Gen (1993-1997)
Jun 18, 2007 11:46 PM
loonyrobert3
Mar 28, 2003 06:21 AM
CamRen
Jan 14, 2003 09:36 PM
