Brake Squeal!! Please help!!!
I have a 2014 GS 350 F Sport RWD and I installed aftermarket rotors and aftermarket pads but they make so much squealing noise when I brake. The first 2 weeks, it is fine and then all of a sudden the squealing comes. I went to Lexus and bought OEM rotors, Pads and shims. I am thinking to install them this weekend. Will going OEM fix the squealing noise? Any one here replaced the front with oem brakes, rotors and shims with no brake noise? Please help!!!!
I have a 2014 GS 350 F Sport RWD and I installed aftermarket rotors and aftermarket pads but they make so much squealing noise when I brake. The first 2 weeks, it is fine and then all of a sudden the squealing comes. I went to Lexus and bought OEM rotors, Pads and shims. I am thinking to install them this weekend. Will going OEM fix the squealing noise? Any one here replaced the front oem brake and rotor and shims with no brake noise? Please help!!!!
Many threads on this if you do a search.
Start with this recent thread :
https://www.clublexus.com/forums/gs-...old-start.html
I read many threads but I am getting different answers. Just want to know if the OEM rotors, pads and shims is the correct way to go when changing the brakes to prevent noise. Thanks.
monsoon we had yesterday in Boston.
-Mike
I have had a problem with my rwd gs350
installed this
CarlsonŽ - Rear Disc Brake Hardware Kit more details on -
https://www.carid.com/carlson/rear-d...leid=329287924
CarlsonŽ - Front Disc Brake Hardware Kit more details on -
https://www.carid.com/carlson/front-...leid=329287925
SHIM KIT, ANTI SQUEAL front and rear set from lexuspartsnow.com
along with lube on the shims and other places where metal to metal meet. Have no squeal as of yet , has been 3 weeks so far hope i holds up.
Hope this helps.
installed this
Hope this helps.
Lexus changed the pad material for the pads on this car, the older stuff brakes a tad better but squeals more. I think on the RWDs, the front rotor design changed as well.
These are the parts I bought. I hope the OEM parts will fix the noise.
2014 GS350 F Sport RWD:
Brake Pads - 04465-30491
Shims - 0494530340
Shim Grease - 0887-80409
Rotors - 4351230371
Rotors - 4351630061
Shims - 0494530340
Rotors - 4351230371
Rotors - 4351630061
My oem pads on my 2015 gs350 were really loud, not too bad in the mornings but on the way home from work man they were loud. Drove me nuts, dealer was no help said the pads are just noisy.
So took it on myself to try and find a way and so far so good. Don't hear a thing now. Just crossing my fingers that it won't return.
Have the none f sport 2015 gs350 RWD, Sitll on the original oem pads and rotors.
installed this
installed this
