Brake Squeal!! Please help!!!
Old Nov 1, 2019 | 01:18 PM
  #31
JDR76's Avatar
JDR76
Originally Posted by Yong3381
JDR76 - Does the noise go away after a few applications on the brake? Might be just rust that set overnight. If it goes away completely after warming up the brakes, I heard it is normal 🤷 but if the noise continues, then might have a problem.
It went away with a few applications of the brakes. I could accept the "it's normal" and that it's just some rust on the rotors that needs to get cleared off a bit easier if I had the issue with other cars. Even my previous IS350 never had this issue.
Old Nov 1, 2019 | 01:19 PM
  #32
peasodos's Avatar
peasodos
Originally Posted by JDR76
That's when I realized that any solution to the embarrassing squealing was not going to come from the dealer. I vowed to fix it myself but never found the time to do so. Unlike my 15, which was a lease, my 19 is purchased for long term ownership, so if/when the problem hits the 19, I'll be more motivated to address it.
Back when I was going through it there were several other forum members on here with the same issue with OEM brakes.
was it the two piece rotors?
Old Nov 1, 2019 | 01:21 PM
  #33
JDR76's Avatar
JDR76
No, AWD so it should be the single piece rotors.
Old Nov 1, 2019 | 01:34 PM
  #34
DAVEB1980's Avatar
DAVEB1980
Its the original set of rotors and the car only has 9100 miles. Should I take it to the dealer now? It does go away after a few stops.
Old Nov 1, 2019 | 02:03 PM
  #35
Yong3381's Avatar
Yong3381
DaveB, if you have a garage, try garaging your car overnight and test it in the morning. If you have no noise then it must be the rust being built up on your rotors when you leave your car outside. Which is normal I heard 🤷
Old Nov 1, 2019 | 02:10 PM
  #36
peasodos's Avatar
peasodos
My car is parked outside all the time. Only time it will make any noise is if there is heavy rain and I get rust on the rotors. It's also not a sqeaking noise, just just some resistance and scarping sound of the rust. This goes away when I brake once or twice.Otherwise no noise at all from parking outside.
Old Nov 1, 2019 | 02:16 PM
  #37
JDR76's Avatar
JDR76
And my car is always parked inside at night.
Old Nov 1, 2019 | 02:20 PM
  #38
Yong3381's Avatar
Yong3381
JDR76 - Oh wow, damn. Yeah, these brakes and rotors for the F Sports are really a pain in the ***. I hope my OEM set stays quiet but I will update in 2 weeks.
Old Nov 1, 2019 | 04:39 PM
  #39
charley95's Avatar
charley95
It's interesting that a lot of owners have this issue and yet I do not. 18 GS 9000 miles with 2 piece rotors with aftermarket pads installed from the day I bought it new. The only reason I went with ceramic was the brake dust issue with the original pads. I wonder if spirited driving and hard braking maybe causes this?! I'm not a spirited driver and not aggressive with my braking. I usually get 50k plus miles out of a front set of pads on average.
Old Nov 1, 2019 | 05:01 PM
  #40
Yong3381's Avatar
Yong3381
@charley do you have a F Sport RWD? If u do, your luckyyyy. Your car is definitely a keeper haha
Old Nov 1, 2019 | 05:33 PM
  #41
charley95's Avatar
charley95
Old Nov 15, 2019 | 12:44 PM
  #42
Yong3381's Avatar
Yong3381
It’s been 2 weeks and I can officially confirm OEM rotors, brake pads and shims stopped the squealing noise. My car is super quiet when braking now. Don’t buy and install anything else other than OEM.
Old Nov 15, 2019 | 12:45 PM
  #43
peasodos's Avatar
peasodos
Amen. Hopefully others will learn from this.
Old Nov 15, 2019 | 12:47 PM
  #44
DAVEB1980's Avatar
DAVEB1980
what is a brake pad shim? Is it something that goes behind the pad? Is the shim a factory part?
Old Nov 15, 2019 | 12:49 PM
  #45
DAVEB1980's Avatar
DAVEB1980
DaveB - Does it only squeal in the morning? Does it completely go away after pressing on the brakes a few times?
the noise seems to lower but does not completely go away.
