Part # 8004530F90 is the headlamp with AFS. I believe headlamps with AFS have a motor that allows them to move left and right when turning to help illuminate the way.
If you check out the diagram on this page, you can see it is NOT the triple bulb LED type. They are the same Bi-HIDs as the standard headlights and look like the standard headlights, just with the ability to swivel.
Would the housings possibly be the same? I came across a deal on the AFS-F90 type and I need to get mine replaced since the lens is chipped on the corner.
Have fun pulling the 90 light apart to put your 80 guts in...I'm pretty sure they're designed only to be broken open. If you're handy with a dremel and the responsible use of loctite, go for it...surely better off buying the suitable ECU for the better light?
edit..Maybe try the afs headlights in your nonafs car...probably won't throw errors because it's not being asked to do anything it can't.
The headlamp housings will be the same, the internals will be diff't. If you get the AFS headlamp, you will likely have an error code or warning light show up on your dash indicating that your AFS isn't working. See this helpful thread: https://www.clublexus.com/forums/gs-...rn-30-a-2.html
There are some online dealers with some great prices...headlamps are expensive but mylparts.com offers a 10% discount with code CL5 for clublexus members. The other option would be finding a used headlamp on eBay of course...
Thinking maybe I wouldn't have to pull the light apart since they look to be the same. Just switch over my old up+down projector on the back with the new up+down+left+right projector/motor/plug?? If your wondering why I am asking so many questions- I am able to buy a reman F90 type for $196 versus buying an F80 elsewhere for about $1100.
