GROM VL2 installed
Wow you are the man!! I finally got it to work! You have to first click on Carplay, then you are taken to a difference screen where it tells you that your UI is disabled. You have to click on the top line 10X! Thanks a bunch!
As a follow up, CarPlay works amazingly well. The only issue is that when someone calls I can hear then perfectly but they hear static. Is this a known issue?
The static is only with CarPlay. My audio settings are at max. When I take the phone cable out then the static goes away.
Hi guys. First time posting here. I have a 2012 Lexus CT200h with Navigation system and today I ordered the GROM VLINE VL2 to get CarPlay in my CT200h which I love to death. It has only 68K miles so my plan is to keep as long as I can. Does anybody here have installed the VL2 in a 2011 or 2012 CT200h?
Those old Lexus seems to be very buggy. GROM have since fixed lot of issues. But be wary you may encounter bugs.
This is a 4th Gen ('13-Present) GS forum, you will not get any CT owners in here. IMO GROM VL2 works best with Gen8 or 9 Lexus Infotainment. Lots of issues with the older models. You can read up on ISF owners ('08-'14) here: https://www.clublexus.com/forums/is-...vline-123.html
LOL didn't mean to freak you out. I'd still try it and see if bugs are gone. Many of those issues were with earlier releases of Vline. I'm sure they fixed most of it now. You do have 30 days warranty and GROM is very good with support IMO. You could try LSailt or Carlink..not sure if they're available for your CT though. Go do some research.
Made an account just to make sure I let everyone here know how terrible my GROM VLine experience has been. They sent me the wrong product, took forever to get back to me and then refused to believe what I was saying. I am trying my best to get it returned but they won't cover shipping or the installation cost. For the price this unit is I would not recommend anyone taking on the risk to have such horrible customer experience. IF the product works (big IF as you will notice in this thread), then lucky you but for that price its just not worth the gamble. Get a bluetooth to aux connecter and an iPhone stand for 5% of the price and you'll get 90% of the functions.
Massive warning - at your own risk, don't make the same mistake I did.
It's not because of "shielding"; your cable was probably made poorly or incorrectly. It may have been soldered wrong and there are wire whiskers causing a short, which gives you a flicker. That was the case with two cables I got from GROM ; I ended up fixing the issue myself as they apparently couldn't. I would call them and tell them to fix it. I fixed mine and I have never had a single case of flicker once I redid the existing cable I had with better workmanship.
This is ridiculous that this is still happening with new installs of this product @gromaudio
That sucks but it's the risk you take to save money. Having the installer supply the unit would take you out of the equation...in exchange for a mark-up! They should pay for the return postage however, being their booboo.
Originally Posted by rokayjon
How did you fix the cables? I am having the same flickering issues and it is driving me nuts.
I desoldered it and rebuilt the cable correctly, now I have no issues with flickering.
I took the “risk” and it was by far the best decision I’ve made in regards to the GS aside from the purchase of the car itself. The unit has been rock solid, and has been an absolute pleasure to use.
On top of that, their support has been top-notch each time I’ve needed it, so I don’t know what happened here. Hopefully they take care of it.
