Wipers Stopped Mid Swipe
Old Nov 1, 2018 | 06:57 AM
Knucklebus's Avatar
Knucklebus
Default Wipers Stopped Mid Swipe
It is raining in South Central Kentucky today and my wipers on automatic made half a swipe up and stopped mid stroke. Auto light is still lit and turns on and off with the button but no function. I turned off the auto feature and they would not rehome. Pushing up to get a mist stroke did nothing. Pulling down did nothing, pulling all the way down produced high speed full time wiping. Pushing up stops them mid stroke. Most annoying.
I continued to fiddle with them and it eventually started working on high and low full time wiping but auto and mist still did not function.
By the time I arrived at work it was all working again, including auto and mist.
Anyone seen anything like this? Any idea where I should start my trouble shooting?
My first thought is to find the connectors for the wiper motor itself and remove, clean, grease and reseat them.
Old Nov 1, 2018 | 07:03 AM
jonathancl's Avatar
jonathancl
I have a theory, something I have seen on three wiper motors.
The lubrication inside the motor and gear housing sometimes ends up on the tracks with the electric contacts that tell the motor what position the wipers are in.
I have three times fixed a wiper assembly by removing the gear housing cover and cleaning the conductive tracks on the primary gear.
The behavior you're describing is consistent with that issue.
Old Nov 1, 2018 | 07:12 AM
Knucklebus's Avatar
Knucklebus
Ah, good news. How long does it last between cleanings?
Old Nov 1, 2018 | 09:26 AM
bclexus's Avatar
bclexus
It is always difficult to troubleshoot a problem when the problem happens intermittently, and even more difficult when the problem happens only once and goes back to working normally as it should again.
Old Nov 1, 2018 | 09:38 AM
RX469's Avatar
RX469
Where is the gear housing located??
Old Nov 1, 2018 | 10:33 AM
jonathancl's Avatar
jonathancl
I have never had the problem reappear after cleaning the tracks. It may be because cleaning the tracks removes excess lubrication, which lowers the chances of it happening again.
Here's a pic from my QX60 motor:
The contacts are on the underside of the pink disc, and they were covered in the white lubricant. My GS430 has the same issue as well as my wife's old TrailBlazer. The problem would come and go until I took things apart and cleaned it up.
Here's a pic of a GS350 assembly:
The gearing, lubricant, and contacts are beneath the black cover.
You can also find the entire assembly on ebay for $50-100, so depending on how valuable your time is, that might make more sense.
Old Nov 4, 2018 | 05:45 AM
kgh31386's Avatar
kgh31386
Same exact thing recently happened with me. I took a video and sent it to my service advisor. It’s embarrasing and pissed me off because it was mid downpour in rush hour with my 2 year old in the car.
They replaced 2 relays and all is good. It was covered under warranty. If you can’t get a video of it, show them this YouTube clip of an IS doing the same thing.
Old Nov 4, 2018 | 09:13 AM
jkeller's Avatar
jkeller
https://www.clublexus.com/forums/gs-...r-problem.html
Old Nov 4, 2018 | 11:34 PM
Jtkotze's Avatar
Jtkotze
guys. it is likely the relay.
there are two relays in the fusebox for the wipers. ones does auto/intermittent and one does the normal wiper function. swap them around and see if the issue goes away. There was service bulilten on the relays. there were a bad batch. Apparently the gent that had assembles these was also working on another assembly line at the time where silicone was used. Some of the silicone residue got to the relay poles and causes issues after a while. Had my relay replaced and issue gone...
Old Nov 5, 2018 | 08:43 AM
Knucklebus's Avatar
Knucklebus
Looks like it is less than $20 on RockAuto. Part number is Wells 1R1467 and seems like a pretty generic relay, fitting fans, wipers and many other things.
Old Nov 9, 2018 | 08:10 AM
Knucklebus's Avatar
Knucklebus
Interesting development. I swapped the two relays and it changed the failure slightly or it might just be less of a failure regardless of relays.
1) The auto wipe will make half a swipe but pushing up to mist makes it move until I let go. If I let go before parking, it will stop wherever.
2) Low and high wiper speeds work just fine now.
That would seem to eliminate the relay(s) as the issue. I'm going to pop the cover off the wiper motor to see if cleaning the contacts improves it.
Old Nov 12, 2018 | 12:23 AM
Jtkotze's Avatar
Jtkotze
The relays are the issue. both faulty. One just not as bad as the other.
Old Nov 12, 2018 | 04:47 AM
Knucklebus's Avatar
Knucklebus
So, I should be able to buy one and make the delay/auto work even if the slow/fast isn't? Or vice versa?
Oddly, it only seems to happen in the rain. Testing with the washers in dry weather works just fine.
rboarman
Feb 23, 2009 09:37 AM
jtrice
GX - 1st Gen (2003-2009)
Dec 20, 2007 10:57 AM
wanderer99
Nov 16, 2006 03:10 PM
cenwesi
Mar 1, 2005 10:31 AM
