Suspension Torque Specs
Old Feb 26, 2018 | 08:52 PM
chrisvo95's Avatar
chrisvo95
Post Suspension Torque Specs
Looking into to buying some coilovers for the GS, but I want to do it right with all of the correct torque specs for the suspension. Any diagram or pictures for '13-'15 GS 350 F-Sport?
Old Feb 27, 2018 | 04:49 AM
Superman60's Avatar
Superman60
Not sure but if you Google it I'm sure you'll find all the specs.
Old Feb 27, 2018 | 12:05 PM
Tcagle's Avatar
Tcagle
Torque Specifications
Part Tightened Nm kgf*cm ft. lbs.
Front shock absorber cap x Body
20
200
14
Front shock absorber with coil spring x Body
67
683
49
Front shock absorber nut x Piston rod
28
286
21
Front shock absorber with coil spring x Front lower suspension arm assembly (for 2WD)
108
1101
80
Front shock absorber with coil spring x Front lower suspension arm assembly (for AWD)
112
1142
83
Front upper suspension arm assembly x Steering knuckle
87
887
64
Front shock absorber with coil spring x Skid control sensor wire
6.0
61
53
in.lbs
Steering knuckle x Front lower ball joint assembly (for 2WD)
150
1530
111
Steering knuckle x Front lower ball joint assembly (for AWD)
120
1224
89
Front upper suspension arm assembly x Body
49
500
36
Front lower suspension arm assembly x Front lower ball joint assembly
125
1275
92
Front lower suspension arm assembly x Front suspension crossmember subassembly
(for
2WD)
135
1377
100
Front suspension No. 1 camber adjust cam x Front suspension No. 2 camber adjust cam (for
AWD)
119
1213
88
Front lower suspension arm assembly x No. 2 lower arm bracket assembly
113
1152
83
Front lower suspension arm assembly with No. 2 lower arm bracket assembly x Body
86
877
63
Front lower suspension arm assembly with No. 2 lower arm bracket assembly x Strut bar
bracket reinforcement (for 2WD)
188
1917
139
Portions of materials contained herein have been reprinted unde r license
from Toyota Motor Sales, U.S.A., Inc., License Agreement TMS1005. See
details here.
Listen
9/22/2016 2013 Lexus GS350 Suspension
> Specifications > Front Suspension > Torque Specifications
http://www.chiltondiy.com/pvt/Conten...d=119538#65467 632626 2/2
Front lower suspension arm assembly with No. 2 lower arm bracket assembly x Side rail plate
(for AWD)
151
1540
111
Body x Strut bar bracket reinforcement (for 2WD)
50
510
37
Body x Side rail plate (for AWD)
50
510
37
Front lower ball joint assembly x Tie rod assembly (for 2WD)
65
663
48
Steering knuckle x Tie rod assembly (for AWD)
65
663
48
Front No. 1 stabilizer bracket x Body
49
500
36
Front No. 1 stabilizer bracket x Front No. 2 stabilizer bracket (for 2WD)
49
500
36
x Front No. 2 stabilizer bracket (for AWD)
78
795
58
Front stabilizer bar x Front stabilizer link assembly
84
857
62
Front stabilizer link assembly x Front lower suspension arm assembly
84
857
62
x Power steering link assembly (for 2WD)
118
1203
87
x Power steering link assembly (for AWD)
102
1038
75
Old Feb 27, 2018 | 12:06 PM
Tcagle's Avatar
Tcagle
Sorry for the ugly post.
Old Feb 27, 2018 | 12:07 PM
Tcagle's Avatar
Tcagle
Here are the rear specs
Rear support to rear shock absorber nut
18
184
13
Rear suspension support assembly x Body (Upper side)
74
755
55
Rear shock absorber assembly x Rear No. 2 suspension arm assembly
110
1122
81
Rear No. 2 suspension arm assembly x Rear suspension arm cover
12
122
Rear suspension member brace x Rear suspension member subassembly
47
479
35
Rear No. 1 upper control arm assembly x Rear axle carrier subassembly
150
1530
111
Rear No. 1 upper control arm assembly x Rear suspension member subassembly
150
1530
111
Rear upper control arm assembly x Rear axle carrier subassembly
190
1937
140
Rear upper control arm assembly x Rear suspension member subassembly
150
1530
111
Rear No. 1 suspension arm assembly x Rear axle carrier subassembly
90
918
66
Rear No. 1 suspension arm assembly x Rear suspension member subassembly
90
918
66
Rear No. 2 suspension arm assembly x Rear axle carrier subassembly
145
1479
107
Rear No. 2 suspension arm assembly x Rear stabilizer link assembly
70
714
52
Rear No. 2 suspension arm assembly x Rear suspension member subassembly
150
1530
111
Toe control link subassembly
70
714
52
117
1193
86
Rear stabilizer bracket x Rear suspension member subassembly
48
489
35
Rear stabilizer link assembly x Rear stabilizer bar
89
908
66
Portions of materials contained herein have been reprinted under license
details here.
Listen
> Specifications > Rear Suspension > Torque Specifications
http://www.chiltondiy.com/pvt/Conten...d=119538#65450 631693 2/2
Rear suspension member brace x Body
19
194
14
Rear suspension member lower stopper x Body
19
194
14
Rear suspension member lower stopper x Rear suspension member
127
1295
94
127
1295
94
Rear upper spring seat x Body
57
581
42
12
122
Rear drive shaft assembly x Rear axle shaft nut
290
2957
214
details here.
05ls430518
Jan 30, 2018 05:56 PM
Celsius
Suspension and Brakes
Mar 22, 2015 09:09 PM
AJ.STYLEZ
GS - 1st Gen (1993-1997)
Mar 11, 2013 08:58 PM
kit cat
24
Mar 7, 2009 01:31 AM
acl15
Aug 29, 2006 08:33 PM
