Engine Fuel pump Noise Reduction.
Old Apr 19, 2019 | 07:38 AM
  #46
jonathancl's Avatar
jonathancl
Just ordered 12605-38010 and 12606-38010 from mylparts.com.
Shipping was only $6 to PA, order total $33.45.
Old Apr 24, 2019 | 10:09 AM
  #47
jonathancl's Avatar
jonathancl
Just installed. Didn’t remove anything, though it was a little tricky to get the right leverage. Ten mins tops. Put pieces in position, snap back and top first, then snap outside.
The car is really quiet at idle now. I’m actually surprised how much difference this made. The sewing machine sound is heavily muted, slight background versus the dominant engine sound it was before.
Well worth $35.
Old Apr 25, 2019 | 01:40 PM
  #48
SC300Es's Avatar
SC300Es
To me, it looks like such a tight space I'm almost afraid to push things around.
Ed
Old Apr 26, 2019 | 11:48 AM
  #49
swat1727's Avatar
swat1727
Hi, I just installed mine. To be honest, I didn't hear any difference before and after. Maybe I don't know what to listen for, but overall it does not reduce cabin noise by any noticable amount. It also was not easy to install. Very tight spaces and the cover is pushing tightly against the metal pipes. I won't take it out, but I won't recommend this to people. Again just my opinion.
Old Jun 18, 2019 | 09:16 AM
  #50
btanchors's Avatar
btanchors
Well, I ordered the parts mentioned at the beginning of this thread several months ago. I finally got around to trying to install them today on my 2017 GS350. It won't fit. Looking back at the pictures in the beginning of this thread, it looks like my pump has more pipes/connections coming out of it than the one in this thread.
Has anyone successfully installed this on a 2017 GS350? If so, did you have to modify it to get it to fit?
Old Aug 31, 2020 | 06:16 AM
  #51
chinee's Avatar
chinee
Does not work for the refreshed 4GS... just confirmed this weekend.
Old Sep 1, 2020 | 03:11 AM
  #52
itsAQ's Avatar
itsAQ
I took mine to Lexus and they changed out the vacuum pump and it killed the sewing machine noise on mine by 80%. I have a 2017.
Old Sep 1, 2020 | 11:38 AM
  #53
byungkuk's Avatar
byungkuk
Can you explain a little bit more? What part number?
Thanks!
Old Oct 13, 2020 | 06:43 AM
  #54
tamermido1's Avatar
tamermido1
For some reason I can't get it in. I think I'm just worried about breaking something.
Old Oct 13, 2020 | 09:41 AM
  #55
chinee's Avatar
chinee
Originally Posted by tamermido1
For some reason I can't get it in. I think I'm just worried about breaking anything.
Virgin? ... LOL (sorry for the moment of immaturity...)
Old Oct 13, 2020 | 09:54 AM
  #56
byungkuk's Avatar
byungkuk
It appears this solution isn’t available for 16+ models. The poster above mentions TSB on vacuum pump which isn’t available to me since I'm out of warranty.
Although I’m not sure if my car even has the problem (Checked via VIN lookup). Just wanted to quiet down the DI noise. Oh well.
Old Oct 14, 2020 | 07:58 AM
  #57
tamermido1's Avatar
tamermido1
Finally got it in! It definitely makes a difference specially hearing it from inside the car!
Old Oct 28, 2020 | 08:45 AM
  #58
CAKETOWN's Avatar
CAKETOWN
so this is for the 2013-2015 2GR-FSE only?
Old Oct 28, 2020 | 08:05 PM
  #59
peasodos's Avatar
peasodos
See my first post, if your high pressure fuel pump looks like that then it will work, otherwise it won't. Doesn't work on the 450h at all since the fuel pump is different.
Old Dec 16, 2021 | 09:55 PM
  #60
Mpat300's Avatar
Mpat300
Has anyone tried or know if this will fit on a IS300 2017 ?
the fuel pumps look identical but online it says it wouldn't fit.
This is the fuel pump on the 3IS looks similar to the pictures posted here in my opinion
