Auto Folding Mirrors
Old Mar 14, 2023 | 02:27 PM
  #151
richard203's Avatar
richard203
Originally Posted by JoshIS408
You need to depin / repin the connector. I had to do this because I sourced the motors only and re-used all my original housing on my 13 F-sport. The only reason I did this was because the cars been custom re-painted, bases wouldn't match and did want to go through the trouble of painting again etc...
nvm got how to open up the connector now just waiting for the repin tool to remove the pin
Old Mar 16, 2023 | 12:45 AM
  #152
richard203's Avatar
richard203
alright just swiped my stuff into the folding mirror, i got a question for those 2014+ with folding mirror do u guys have alittle play on ur mirror? i just got 1 mirror right now picking up the other side on fri and just wondering is it normal or this one is defective because my 2013 the mirror is tight no move might and this one have a bit movement. let me know i will post pic of how to remove the pin and the connector cover after i finish all this.
Old Mar 16, 2023 | 11:05 AM
  #153
JoshIS408's Avatar
JoshIS408
- - G T V I P - -
No play at all. In order to de-pin, get a small flat head screw driver and gently press down on the top of the terminal head where the red line is (not sure if that term is correct lol). Once pressed down the wire should come out easily.
Old Mar 16, 2023 | 05:06 PM
  #154
richard203's Avatar
richard203
got it i guess when it get power it tightening up the side mirror spring now it doesn't move
Old Jun 10, 2024 | 07:03 PM
  #155
vtecpapi's Avatar
vtecpapi
3rd Gear
Originally Posted by peasodos
The plug has a rubber gasket in it, not easy to de-pin and I would probably damage trying.
Actually that picture is the back of the 2014+ mirror you have to use the 2013 mirror for BSM to work so the color of the wires are different.
I ended up cutting the harness it plugs into and flipping that instead.
So Im planning to do this swap, unfortunately I cracked my driver glass. Is it still possible to use the 2014 Glass and just cut and flip the wires? Or is the 2014 glass completely unusable in the swap? Thanks
jracerlmn
Apr 26, 2019 12:07 AM
mrcheap
RX - 4th Gen (2016-2022)
Mar 6, 2017 03:41 PM
imrat
May 24, 2015 06:46 PM
Ashleyd
Apr 2, 2014 03:47 PM
inecstaz
May 8, 2006 11:20 AM
