12.3" Default Screen / Audio Mute "Button"
Old Jan 18, 2017 | 07:27 AM
Handi's Avatar
Handi
Default 12.3" Default Screen / Audio Mute "Button"
On the 12.3 display, is there a way to either set a default screen or to prevent the screen from changing?
My always goes back to the Nav. screen.
Even when I am moving the cursor around trying to select an song/artist it will switch to the Nav. screen and it is getting frustrating.
Also am I missing something, I find it hard to believe that the audio system (non-ML) doesn't have a "MUTE" button.
Is it so obvious I am over looking it or is it we don't have one?
Regards
Randy
Old Jan 18, 2017 | 07:33 AM
teezee1000's Avatar
teezee1000
The mute is the play/pause button.
bjnzzzle's Avatar
bjnzzzle
Regards
Randy
First, you can turn that feature off by going to Menu/Settings/Nav/Nav Details and turn off the Auto change screen.
Second, you can hold the MODE button on the steering wheel to mute the music or there is a mute button on the right side of the cd slot
Old Jan 18, 2017 | 09:22 AM
Handi's Avatar
Handi
Thanks, both of those worked. BUT, there are conditions with the mute depending on the source.
I will test it at lunch.
Also my menu path for the popup window isn't what your showing. Im not sure if it a model year difference.
I will log my path and post it after lunch.
Thanks for your assistance. Much faster and better than stopping by the dealer on the way home to let them figure it out.
Thanks again
Old Jan 18, 2017 | 09:29 AM
bjnzzzle's Avatar
bjnzzzle
Thanks again
My bad, the menu path is Menu/Setup/Nav/Nav Details
Old Jan 18, 2017 | 11:24 AM
Handi's Avatar
Handi
The path to turn off the Automatic Window Changing, MENU "Button" / SETUP / GENERAL (then scroll down once) / "AUTO SCREEN CHANGE" Turn OFF
I drove a couple of miles in 10+ minutes and the screen did not change.
To mute the Sound
SOURCE "MODE BUTTON" (Hold for 2 seconds +) / Play/Pause (Button at Right of Disc Slot)
AM/FM - - - - - - - - Pause Sound (No longer LIVE Radio) - - - - - Pause Sound (No longer LIVE Radio)
USB - - - - - - - - - - Pause - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Pause
SAT - - - - - - - - - - - Mute - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Mute
DISC - - - - - - - - - - Pause - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Pause
BlueTooth - - - - - - - Pause - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Pause
Pandora - - - - - - - - Pause - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Pause
For whatever the reason you can not Pause the SAT source, too bad it doesn't capture the audio and let you build up like you can on the AM/FM.
Oh well, this has giving me a better understanding of it.
Old Jan 18, 2017 | 11:57 AM
bjnzzzle's Avatar
bjnzzzle
To mute the Sound
You're right, I was at work and could not remember clearly lol
Old Jan 18, 2017 | 12:11 PM
Handi's Avatar
Handi
Hey, not a problem. That's why I had to wait and write it down. Trying to memorize all of the Menu's this car has is impossible for me.
When I was much younger and lived this stuff I might of been able to recall it but now no way.
My brain is still at the DOS 6.0 level, and the memory is bad and can no longer be purchased. :^)
clemgrad85
Apr 27, 2020 05:45 PM
mike171333
Jan 12, 2013 10:30 AM
JohnS
Sep 15, 2011 08:50 AM
nobuddy
Hybrid Technology
Apr 13, 2007 04:17 PM
GS3Tek
GX - 1st Gen (2003-2009)
Jul 24, 2005 09:04 AM
