Nav Screen Display Question
Is there a way I cannot have the Nav screen default back to map view but instead to stay on the Audio screen?
I can do that on my Honda but in the Lexus it switches back to map view after I select the Audio button to see the Satellite Radio after a short period of time. I cannot find the option in the Nav manual.
Thanks, John
Thanks, John
There is a setting for default back to map screen or something. This can be on or off. When on, it'll flip back to the map no matter where you are. If it's turned off, the screen will stay on whatever you select indefinitely.
So if you flip it to Audio, it'll stay there. Press Audio again and it'll take you to previous screen whether it be the map or even the Climate screen.
Can't remember where the setting is, but just poke around.
I appreciate it you can find it. I have checked the set up but it is not obvious to me which one sets it. The manual is not very helpful as it does not seem to explain the functionality of each thing only how to reach the settings.
