traction control engaging while car is stopped?
Old Jun 17, 2013 | 06:01 PM
Khalendar's Avatar
Khalendar
Default traction control engaging while car is stopped?
so today for the 2nd time in the past month, the traction control on the car randomly engaged while the car was stopped at a stop light, both times the car was stopped for a while before it happened. if i put the car into park it would disengage.
has anyone else encountered this?
Old Jun 17, 2013 | 06:46 PM
yardie876's Avatar
yardie876
Weird. Explain a little more what exactly what happened when it went off. Did the slip light come on?
Old Jun 17, 2013 | 10:41 PM
dchar's Avatar
dchar
It's probably the hill hold feature. If you depress the brake all the way when completely stopped, the light flashes. When you let off the brake, it will hold a few seconds then release.
Old Jun 17, 2013 | 10:51 PM
Khalendar's Avatar
Khalendar
yeah that was probably it, was just reading the manual and i do know that i was adjusting myself in the seat today and probably pressed down on the brake more and there was a beep with the indicator flashing.
thanks!
Old Jun 17, 2013 | 10:58 PM
nickhaaa's Avatar
nickhaaa
That happened to me the other day too! For the same reason. I was stretching actually and it happened. I pressed in the brakes all the way a few more times to make sure that was what was triggering it.
So what is this hill hold feature? What's the functionality of this? Is it to stop the vehicle from rolling backwards on a hill before getting on the gas?
Old Jun 17, 2013 | 11:16 PM
terrycs's Avatar
terrycs
I would have never thought hill holding is needed on an AT.
Old Jun 18, 2013 | 06:42 AM
LexusGSFGO's Avatar
LexusGSFGO
Exactly right. On steep hills even cars with automatic transmissions can start to roll back between the time you release your foot off the brake and press down on the accelerator. I only needed to use this feature once, but it works.
Old Jun 18, 2013 | 07:26 AM
Bill_GS3's Avatar
Bill_GS3
CL Folding 3,000,000
I have used this feature very often. I live in FL, our highest hill is an over pass.
I use it when at a light. I activate it, release the pedal and then lightly hold it. No excessive pressure is required.
Old Jun 18, 2013 | 11:19 AM
onexcite's Avatar
onexcite
This feature very useful if you live in the Bay area.
KJD3
Jul 15, 2022 02:07 PM
Jack777
Jan 24, 2015 06:47 PM
MyCarRx350
RX - 3rd Gen (2010-2015)
Oct 25, 2014 07:31 AM
shrinkwrap
Mar 29, 2014 03:35 AM
tastfulmod
Sep 18, 2011 10:00 PM
