Hey good morning everyone . I own a 2015 lexus gs 350 and a lately it start shaking when accelerating around 25 mph to 45 mph and vibrating while idling on drive mode. Have anyone experienced this ? If yes how you fix it ?
@bpayano25 - The shaking when accelerating (even at low speed and partial throttle) could be coming from a number of things; such as the transmission torque converter, dirty engine MAF (Mass Air Flow) sensor, worn engine mounts, damaged axle or hub, or even a bent wheel or damaged tire - but the issue is coming from something with mass that is rotating or from something that is spinning and/or out-of-balance.
The vibrating at idle with the vehicle stopped (shouldn't make any difference which mode it's in) and assumed in Drive Gear reduces a couple of the above possibilities, but the issue is coming from engine alone, such as a dirty throttle body or engine MAF (Mass Air Flow) sensor, a defective oxygen (O2) sensor, or worn engine mounts.
By chance - have you had the battery disconnected recently when this issue started - or by chance have you topped up with gas recently where you put in much more gas after the nozzle automatically cuts off? The reason I ask is because sometimes when the battery is disconnected it displays the results of a dirty throttle body or MAF sensor causing the engine to run rough - - and overfilling the fuel tank can damage the charcoal canister, which is part of the Evaporative Emission Control (EVAP) system, causing the engine to run rough.
Reason: orthography
BC already gave you quite a few good starting points and possibilities. Two quick things that come to mind: 1) Rough idle: something simple like bad gas could be the culprit for the sudden rough idle problem - fill up at a different brand gas station to see if that helps; 2) Shaking @ 25-45mph: this sounds like a suspension issue to me (tires worn, alignment issue, bent wheel).
