2015 gs350 crankshaft position sensor location??
Old May 5, 2023 | 06:54 AM
Mtandle's Avatar
Mtandle
Default 2015 gs350 crankshaft position sensor location??
Hello everyone. Can someone help me out and guide me to where exactly is the crankshaft position sensor location on my 2015 gs350?? Ty
Old May 5, 2023 | 01:57 PM
bclexus's Avatar
bclexus
Haven't I already told you where the engine crankshaft position sensor is located in the other thread you started asking about the location of sensors?
Old May 5, 2023 | 03:00 PM
Darknite's Avatar
Darknite
1st Gear
Hi, I actually followed that video and there is no crankshaft position sensor located on my vehicle in that particular location on my 2015 gs350. Any other suggestions? Thanks in advance!
Old May 5, 2023 | 04:25 PM
bclexus's Avatar
bclexus
@Darknite - See Item #6 Crankshaft position sensor (CKP) (located on the front side of the engine under exhaust manifold)
This view is with the cosmetic engine cover installed on a 2015 Toyota Camry with 3.5L 2GR-FE engine
Listing:
  1. Fuel injectors (located next to the intake manifold)
  2. Mass airflow sensor (MAF)
  3. Camshaft position sensors (CMP) (located on top of each cylinder head cover at the front and rear)
  4. Oil pressure switch (located at the lower front of the engine)
  5. Knock sensors (KS) (located under the intake manifold
  6. Crankshaft position sensor (CKP) (located on the front side of the engine under exhaust manifold)
  7. Engine coolant temperature sensor (ECT) (located at the rear of engine)
  8. Ignition coils (located on each cylinder head cover)
  9. Air Fuel Ratio Sensor (AFRS) (located in each exhaust manifold)
  10. Throttle position sensor (TP)
  11. Camshaft Oil Control Valves (at the front of each cylinder head cover)
Old May 5, 2023 | 04:37 PM
bclexus's Avatar
bclexus
@Darknite - This is a 2GR-FE engine out of a Lexus ES350 showing the location of the engine crankshaft position sensor:
Old May 6, 2023 | 09:02 AM
Mtandle's Avatar
Mtandle
I believe my oil dip stick Is located on the battery side of motor I have a 2gr FSE. Is the sensor located same is on the 2gr FE??
Old May 6, 2023 | 10:56 AM
bclexus's Avatar
bclexus
I think you should be able to find it.
Old May 8, 2023 | 10:43 AM
MikeFig82's Avatar
MikeFig82
jrk1956
Apr 7, 2021 09:05 AM
daveyjos
Jul 16, 2018 10:00 AM
nitins
Jul 1, 2017 04:09 AM
aptekcom
Dec 11, 2007 08:43 AM
