GS350 AWD CV Axle recommandation
Old Dec 24, 2021 | 10:25 AM
MadMikeLS4's Avatar
MadMikeLS4
Default GS350 AWD CV Axle recommandation
It's time to change the Front cv axles on my 2007 gs350 awd with 200k. At least one side is missing the outer boot clamp and i get a crunch/pop when turning hard or accelerating hard.
I really want to avoid paying 800dollars per axle and the labor cost to do the job. Rockauto has reman cardone or trackmotive axles for less than 100 per side. Any other reasonably priced options out there? It doesn't have to last as long as oem. Planning to keep the car to 250-300k miles.
Old Dec 24, 2021 | 12:31 PM
ibidu1's Avatar
ibidu1
I replaced my cv axle with a reman cardone from rockauto, excellent and its been on there several years now.
I would avoid replacing the long cv axle im not sure if its driver or passenger side. But theres a short side and a long side, the long axle side are a pain in the butt to remove, they get super stuck. Guys have built jigs just to remove them.
Old Dec 25, 2021 | 09:00 AM
MadMikeLS4's Avatar
MadMikeLS4
unfortunately i believe it's the passanger(longer) side that's the culprit. Debating wether to take it to a shop or attempt myself.
Old Dec 25, 2021 | 10:22 AM
ibidu1's Avatar
ibidu1
Save yourself the headache and take it to a shop, its a nightmare! Or have them replace the cv boot and repack the joints on the car, using a cv axle boot spreader.
Old Dec 25, 2021 | 03:30 PM
MadMikeLS4's Avatar
MadMikeLS4
I'm assuming the repacking method wouldn't save a joint that's already bad/making noise?
Old Dec 25, 2021 | 09:06 PM
ibidu1's Avatar
ibidu1
Correct, if its making noises then it needs to be replaced.
Old Mar 28, 2022 | 02:26 PM
chuckGS350's Avatar
chuckGS350
Did you have any issue with the ABS sensor ring on an after market CV axle?
My driver side inner CV boot is finally torn after leaking for 2 years.
Old Mar 28, 2022 | 03:39 PM
ibidu1's Avatar
ibidu1
What brand of cv axle did you run? Ive run cordone from rockauto with no issues
Old Mar 28, 2022 | 04:46 PM
chuckGS350's Avatar
chuckGS350
I am going to have it replaced tomorrow at the shop. I forgot to ask. I will know tomorrow.
Not sure if I want to replace the passenger side also.
Old Apr 2, 2022 | 07:43 PM
chuckGS350's Avatar
chuckGS350
Toyota replaced my front axles. The parts are NCV. They had a hard time replacing the passenger side. Just like you said. They also said the front bearings start making noise. Will probably need to replace soon.
RainbowTrl
Jan 19, 2017 02:29 PM
Charlie088
Jan 10, 2011 07:36 AM
mikedozz
May 27, 2009 01:54 PM
ServerTech
Mar 10, 2007 01:32 PM
