Transmission shudder
in glad you got the ecu fixed. Did you ask them which part was broken? Since you are EE and all. Maybe you can probe them a bit more since it’s lifetime warranty and you still have issues with accelerating out of 1st gear. Might be a good idea to flush the trans fluid once more in case the rough shifting caused debris to contaminate.
might be a good idea to keep it in snow mode until you change fluids to try.
good luck!
good luck!
yeah snow mode is on all the time and I’m starting to feel maybe second is also holding slightly longer than it should but I’m not sure right now. Either way, I’m hoping to be able to properly check the solenoids if I can get access to Techstream software. Once I test the solenoids, I’ll do another flush, drive for a bit, and check for any improvement.
Does anyone who has used techstream before know if it can run transmission tests?
to fix the shudder, do a fluid change/flush OR the additive. Not both.
About a week ago I replaced the fluid in my car for the 3rd time; about 2.8 quarts came out and it already looked better than before. Disconnected the battery while I was doing it as well so the computers can relearn everything, and I'm pretty happy to say that the shudder is practically gone! It'll hiccup VERY subtly once in a while but for all intensive purposes, it's gone.
I still plan on doing this a 4th time along with a transmission filter change but for the time being, I'm very happy
but the good news is that the transmission still feels really good with several thousand miles on the 3rd change. I'll post an update after the 4th change and trans filter replacement but I'm not sure when I'll get around to that.
It was a costly job, but the car drives completely differently and much better to drive!
Well worth the cost (for me)
also, it turns out that my issue of the gears being held too long wasn’t a transmission issue, but a wheel bearing issue. It took me a while but I finally diagnosed one of the rear wheel bearing being faulty and got them both replaced. My mechanic broke both abs sensors in the process (you’re supposed to remove the abs sensor before putting in the new wheel hub), but when I drove the car (no speedo, no abs, no power steering b/c of the broken sensors), the car was shifting through gears no problem. It felt like a completely different car.
Anyway, the bearing being bad gave the sensors bad speed readings, meaning the computer’s timing was being thrown off. That plus the braking effect from the misaligned bearing meant inconsistent performance.
it’s all fixed now though. Got oem sensors and had them replaced at a Lexus dealer, and also got the F Sport away bars installed while it was there.
It’s a completely different car now. Almost 0 body roll and acceleration is very nice.
I thought I was losing my mind but it feels good to know I wasn’t.
VINDICATION.
VINDICATION.
I keep considering the sway bars as everyone who has added them has said it's transformed the car.
