Transmission shudder
Old Dec 14, 2021 | 05:12 PM
artfil91's Avatar
artfil91
Originally Posted by AmanES300
Hiya,
I have this same issue with my '09 GS350 AWD. I bought it with 79K miles and changed the transmission fluid myself soon after I noticed the shudder and noticed an improvement in severity. It still happens about 80% of the time when I drive, but it doesn't happen as violently nor as often.
I suspect the filter because for me, the first 15mins of driving, it doesn't happen. After 15mins and car is all warmed up, it begins to happen. I'm thinking, maybe when the fluid is warmed up, the filter begins to be clogged with whatever is in the pan because after that first 15 minutes, shifting is nowhere near as smooth as when I drive it after warming up at idle, or when I let the car sit for a bit and then drive. I have parts for a transmission filter and pan swap (my pan is rusted a bit and the overfill bolt is stripped to the point where I cant get it off). I'm not sure when I'll do the swap though.
EDIT: for clarity, my issue matches your description EXACTLY, except for when it happens. Mine does it after the car is warmed up and I've been driving for about 15mins.
I'm glad you brought that up because mine has been behaving the same now. It'll be pretty smooth when cold and then begin shuddering once warmed up after 10-15 mins of driving. This issue first started a few months ago when the weather was warmer and now temps are much chillier so perhaps that explains why the behavior changed. Fortunately, it's not shuddering as badly as before after doing 2 fluid changes but still has plenty of room for improvement.
Old Dec 14, 2021 | 06:56 PM
AmanES300's Avatar
AmanES300
Can you decode your vin and check when the car was manufactured?
EDIT: just realized not all manufacturers put the manufacture date in the vin. It’s probably in the door jam area.
Old Dec 17, 2021 | 02:23 AM
STEN714's Avatar
STEN714
10th Gear
Originally Posted by ibidu1
I have an 08 awd with 200k miles and mine does not shutter, maybe you need to do a couple more fluid changes if you noticed dark fluids coming out. Also did you replace the front and rear differential fluids? Im wondering maybe your shutter is coming from the front diff, as it uses clutch packs to transition the power. So if the fluid is super dirty or empty it may shutter the front end.
Does it happen while in a turn?
Hi there I'm new here and I HAVE experienced the shudder while turning at higher than normal speeds myself. Tbh I'm not sure if I'm running my gs300 (2006) with less than normal atf fluid capacity. I tried removing the overfill drain plug but just wouldn't budge. I decided to just add 2 1/2 quarts of atf (lexus aws atf that is) and call it a day. This was the second time I drained and filled. First was with filter. Can someone help me? I noticed this morning on a cold start when I put it on drive it just wouldn't go. It reved and no movement. I tried reversing and nothing. I then put it in park and waited a bit. After a minute or two I put it back to drive and it moved slowly but surely picked up speed. Shifting it off seems to shift too soon (low rpms) could it be that I didnt add the right amount of fluid to the pan or maybe my transmission is going out. I really hope not but I will do another drain and fill because last drain was pretty dark tbh. Any help is much appreciated. Stay bleesed!
Old Dec 17, 2021 | 12:52 PM
ibidu1's Avatar
ibidu1
Did you strip the head on the allen bolt for the dip stick tube? Or is it just not budging? Did you use a allen socks on a breaker bar? Tapping on the head with a hammer lightly helps loosen the tension a bit also. But I would follow the procedure allow the transmission fluid to rise to operating temp and then open the drain plug and bleed off the excess. These cars are very sensitive to fluid levels, so if I were you I wouldnt drive the car until you fix the level or you will cook the clutches in the transmission.
Old Dec 17, 2021 | 12:55 PM
artfil91's Avatar
artfil91
Agreed. Plus if it's stripped beyond saving, probably best just replacing the whole pan.
Old Dec 17, 2021 | 12:56 PM
artfil91's Avatar
artfil91
And what do you mean by "turning at higher than normal speeds"? Were you getting a shudder cornering at high speeds?
Old Dec 21, 2021 | 11:34 PM
STEN714's Avatar
STEN714
10th Gear
Sorry for the late reply I'm new here so I haven't been on for a couple of days. No and yes. It didn't strip at first. I actually twisted the allen head I used at first, no kid! I then tried using a socket hex key 5mm to be exact and stripped it after a couple of tries. I decided to add 2.5 quarts again because even after the first drain and fill the fluid came out dark brown color. So take note that this was my 2nd drain and fill. The first was with filter aswell. I decided since I had already changed the filter I would just drain and fill. After the last drain and fill which was on the 18th I believe car drove better than the last time. Not getting those shudders anymore but it's still not shifting how it should. There's times where it shifts at proper rpms and timing and there's times where it shifts way too soon. Maybe the fluid needs to mix in well a lil more like our brother said up there and drain and fill a couple more times? What u guys think. I am considering replacing the pan or maybe welding to the drain plug and replacing it after? What u guys think...
Old Dec 21, 2021 | 11:41 PM
STEN714's Avatar
STEN714
10th Gear
Yes will do for my next drain and fill maybe my tranny can still be saved
Old Dec 21, 2021 | 11:44 PM
STEN714's Avatar
STEN714
10th Gear
It would shudder when I would turn right on an intersection going faster than one should. In other words were u feel like car lean when turning and thus traction control should kick in
Old Dec 22, 2021 | 12:37 AM
ibidu1's Avatar
ibidu1
My 08 GS350 AWD does this aswell, when it breaks traction (traction light flashes) in one of the 4 wheels. Its compensating for the loss in traction, this is a normal thing with the awd system.
Old Dec 22, 2021 | 12:49 AM
ibidu1's Avatar
ibidu1
I dont think you need a new fluid pan, you just need to remove the stuck allen bolt. Most likely the dealer will sell you a new plug, breather/dip stick, aswell as a gasket. To remove the stuck bolt, I would first try channel locks, and maybe tap on the head slightly with a hammer. If the channel locks do not work then you can weld a nut to the bolt itself and easily remove it.
Then follow the procedure to drain off the extra fluid you poured in
Old Dec 22, 2021 | 06:19 AM
artfil91's Avatar
artfil91
Yeah I don't think that's related to the transmission. This shudder usually only occurs on light acceleration. What you're probably feeling is the traction control kicking in. Does the orange TC light flash on the dash while this is happening?
Old Dec 25, 2021 | 05:50 AM
awdlyfe's Avatar
awdlyfe
Change out all the fluid and report back.. this is a common AWD issue
Old Dec 30, 2021 | 08:44 PM
AmanES300's Avatar
AmanES300
Hey everyone. I just got my car back after having my mechanic swap the pan and filter. He ended up changing about 5.5qts on the job (this may be too much so if someone knows, please let me know), but I also had him add something called instant shudder fixx by lubegard (recommended in another CL post). It’s supposed to fix any fluid issues the torque converter may have and does not negatively impact the fluid. Do your own research on it. Did my own and decided to go for it. I got the car back today and put it through its paces. No shudder at all so far. I will update in a week or so. If you have questions, ask away.
Old Dec 30, 2021 | 11:39 PM
ibidu1's Avatar
ibidu1
awesome let us know
