Transmission shudder
Old Jan 5, 2022 | 07:53 PM
  #31
AmanES300's Avatar
AmanES300
Great news. No shudder at all since the pan, filter, and oil were changed (along with adding the lubegard additive). I also reset my ECU so it can relearn the new transmission performance (some transmissions adjust shift timing depending on ATF lubricity and other factors). The only issue I have left is when stepping on the gas quickly after braking at low speeds (1st gear), the engine will rev to 2K RPMs with no power for a sec before finally shifting and putting the power down (almost as if I rev’d while it was in the middle of shifting gears). Anyone else have/notice this behavior?
I’d recommend trying the additive first and then swapping oil and filter if it doesn’t work, that way you save money. I just decided to do all of it at once since I was going to have the pan replaced anyway and didn’t want to have to pay my guy a second time (I’d have added the additive myself first, but it’s been brick out).
UPDATE 9-1-22: Turns out, the issue of the car hesitating when giving it gas from a near stop was due to my rotors! They were so rusted/seized that the transmission computer was getting so confused it couldn't decide which gear to go into. I'd been driving with dragging rotors/brakes the whole time lol. A lot of my transmission complaints probably stemmed from the rotors.
Old Jan 5, 2022 | 09:17 PM
  #32
ibidu1's Avatar
ibidu1
Awesome how many oz of the lubegaurd did you use?
Old Jan 5, 2022 | 09:46 PM
  #33
JDMFiend's Avatar
JDMFiend
I've been following your thread recently, so I'm glad to hear you are making progress. I also wanted to know how much of the Lube Gard was added to your transmission fluid? I'm in the process of doing the same to my GS430 in the coming weeks.
The hesitation you have mentioned had happened to me a few weeks ago, since changing the transmission fluid and filter. My transmission would rev but wouldn't drive. I would have to put it into reverse and back into drive, which would fix it. I assume it's something related to the fluid going around the system as the issue only happens when it's been from a cold start within 1-3 mins of pulling away. It's stopped doing this of late and I'm 99% sure it's related to the fluid drain and refill - because it never did this before.
Old Jan 5, 2022 | 10:27 PM
  #34
ibidu1's Avatar
ibidu1
The aisin transmission is very sensitive to fluid levels, you more likely have too much or too little fluid in the transmission. Also how was the fluid condition when you first drained it, was it dark with odor? Another possibility is worn clutch plates inside the transmission.
Old Jan 5, 2022 | 11:10 PM
  #35
JDMFiend's Avatar
JDMFiend
I didn't change it myself, a local specialist did. I did ask them to save some of the drained fluid and it was pretty much the same colour as the new fluid - like a cherry red colour. I've had the car less than a year, so I assume the last owner has had the same thing done and sold me the car without telling me the issue!
Old Jan 6, 2022 | 05:19 AM
  #36
AmanES300's Avatar
AmanES300
I added the full container it comes in. It’s a 2oz container.
Old Jan 6, 2022 | 05:23 AM
  #37
AmanES300's Avatar
AmanES300
Yeah I need to do the ATF level procedure. From what my guy told me, he filled the transmission up till it started draining from the overfill bolt, but that was either room temp or cold fluid. I want to do it soon, just need to find the time. I’ll likely do it this coming Sunday and update here.
Old Jan 7, 2022 | 10:12 AM
  #38
STEN714's Avatar
STEN714
10th Gear
I had that happened to me idk if u read my post up there but tbh I think the cause is changing the filter at first drain and fill. After reading through some of these threads I highly recommend 1st time just drain and fill. Disconnect negative battery terminal to reset ecu. Drive for a couple of miles (I drove for about 150-200miles at normal driving conditions) drain fluid and check amount that drained to see if there was any change in amount filled to amount drained. Fill with about 3 quarts. Follow proper fluid warm up procedure and drain excess fluid. Drive again for 150-200 miles at normal driving. Drain fluid and check amount that actually drains out aswell as color and chenge filter this being last drain and fill.
Old Jan 7, 2022 | 10:21 AM
  #39
STEN714's Avatar
STEN714
10th Gear
So far my car has been driving way better than the first time I drained/changed filter/filled. I think the car needs to adjust to the quality aswell as capacity of the fluid knowing these are electric transmissions being ran by a bunch of sensors. I still need one last time drain and fill but with filter (again) but the only reason I'm changing the filter (again) is because the fluid has been coming out pretty bad even after 3 drain and fills. So this is my 4th and last drain and fill but only because I made the mistake of replacing the filter the first drain and fill. Should be doing it in the next week or 2. I will update on driving performance.
Old Jan 8, 2022 | 07:24 AM
  #40
AmanES300's Avatar
AmanES300
Hey everyone. Just did the ATF overfill procedure and it makes a world of difference. The shuddering is still gone, but now the transmission doesn’t hesitate at all. The issue I described at low speeds is no longer there and the car drives likes it’s brand new. The excess fluid seems to add too much fluid resistance than the transmission was designed for. The extra fluid causes something in the transmission to have too much inertia when braking and throws off the shift timing for 1st gear. I’m also fairly sure this actually was reducing my braking performance (extra inertia to deal with) that I could feel. Now when I brake, I can visibly see the RPMs on the engine drop very quickly when the gears shift. The car is also shifting gears faster it seems.
DO THE FLUID LEVELING PROCEDURE EVERYONE.
Old Jan 8, 2022 | 10:59 AM
  #41
STEN714's Avatar
STEN714
10th Gear
Hey everyone. Just did the ATF overfill procedure and it makes a world of difference. The shuddering is still gone, but now the transmission doesn’t hesitate at all. The issue I described at low speeds is no longer there and the car drives likes it’s brand new. The excess fluid seems to add too much fluid resistance than the transmission was designed for. The extra fluid causes something in the transmission to have too much inertia when braking and throws off the timing for the gear shift 1st gear. I’m also fairly sure this actually was reducing my braking performance (extra inertia to deal with) that I could feel. Now when I brake, I can visibly see the RPMs on the engine drop very quickly when the gears shift. The car is also shifting gears faster it seems.
Nice! I'm glad it worked out. So did u end up using the additive on the last drain and fill or did u just drain and fill with atf? Yes I need to do level procedure on mine too cuz my damm atf overfill allen bolt won't budge. Will be drilling a hole and using a spiral screw extractor to remove it. Wish me luck!🤞
Old Jan 8, 2022 | 11:01 AM
  #42
STEN714's Avatar
STEN714
10th Gear
BTW can anyone actually recommend an additive for the transmission they have ran for thousands of miles without any issues on the contrary positive results? I want to consider it but too scared to try it lol
Old Jan 8, 2022 | 11:11 AM
  #43
AmanES300's Avatar
AmanES300
Added it on my last fluid change which was when the filter and pan were changed (about 5.5qts of new fluid). I recommend doing the fluid or adding the additive separately first so you can know if the additive fixed it or if the fluid change fixed it. I don’t know on mine since all the work was done at once.
As for the bolt, the part number is 9034110021. You can grab it from either a Toyota or Lexus dealer, but call ahead to make sure they have one in stock. I have a lot of dealers around me but only one actually had it in stock and it was the last one. There’s also a washer that goes with it, part number 3517830010. Same advice here.
Old Jan 8, 2022 | 03:43 PM
  #44
STEN714's Avatar
STEN714
10th Gear
Okay so on your last drain and fill (which was when u charged filter aswell) that when u added the lubeguard correct? After that u only did level procedure to drain excess fluid but u didn't change fluid again am I right?
Old Jan 8, 2022 | 03:51 PM
  #45
STEN714's Avatar
STEN714
10th Gear
Oh and yes I actually went to the dealer to get the fluid plus I asked about the bolt and they had it plus washer. Thing is they give me a bolt that is the same as the drain bolt. Dude said they might of changed it to that now since "its a pain in the @ss" removing allen hex bolt. Should I worry about fitment? Did u get the same but Allen hex flat plug?
