2008 GS 460 Strut Replacement
Old Mar 24, 2021 | 01:25 PM
lexuskev's Avatar
lexuskev
Default 2008 GS 460 Strut Replacement
Well I just turned 75,000 miles in my GS460 and have an original strut leaking in the rear (or is it a shock??).. I guess getting 13 years out of the first set I can't complain! Would you just replace the leaking one in the rear or both?? Is this a dealership purchase?? I'm sure this won't be cheap! Oh well... Thanks for any help!
Old Mar 24, 2021 | 09:59 PM
energie8's Avatar
energie8
I had one leaked and replaced all 4 on my 08. Bought 2 from rockauto KYB and the other 2 from the dealer. Then went to a local shop to get them installed.
Old Mar 24, 2021 | 10:54 PM
ibidu1's Avatar
ibidu1
A little bit of leaking is ok, a lot is not. If there still dampening leave them. You can replace them with aftermarket kyb, there pretty cheap on rockauto.com and you order for a rwd GS350, they fit with no issues. Aftermarket does not have adaptive suspension, so if your car came with that option (rare option) you can still use the kyb but you just leave the top servos disconnected and you will not have issues.
Old Mar 25, 2021 | 03:25 AM
lexuskev's Avatar
lexuskev
I checked Rock Auto and they did not offer ANY?? I thought that was strange and figured my only option was the dealer?? My car came with a Adaptive Variable Suspension..
Old Mar 25, 2021 | 04:35 AM
lexuskev's Avatar
lexuskev
Originally Posted by lexuskev
I checked Rock Auto and they did not offer ANY?? I thought that was strange and figured my only option was the dealer?? My car came with a Sport Mode option..
Old Mar 25, 2021 | 06:50 AM
lexuskev's Avatar
lexuskev
I called KYB and they DO NOT offer shocks/struts for the GS460!!! She said I would have to go back to the dealership! Wow!
Old Mar 25, 2021 | 08:37 AM
mspearl95's Avatar
mspearl95
lexuspartsnow shows the same part numbers for struts for the gs350 and the gs460. rockauto lists struts for the gs350, and most likely you could just order those ones. you'd still be sacrificing your AVS tho.
Old Mar 25, 2021 | 11:37 AM
ibidu1's Avatar
ibidu1
You will need to buy struts for a RWD GS350 if you want to run KYB aftermarket on your 460. KYB is an oem supplier for lexus, so youre getting an oem strut. Because you have the adaptive suspension you would need to leave it unplugged. Many 460 owners have used KYB's, it beats paying the insane dealer prices.
I just checked dealer msrp on oem strut is 321 each for the front and 358 each for the rears. Youre looking at $1,358 minus tax.
KYB $82 rears 87 fronts and theres a rebate on them, but without the rebate $344 plus shipping
But like I mentioned if youre not getting a bouncy ride just keep the stock setup. I replaced my rear struts at 130k miles with the kyb and they were fine but I replaced them hunting a tire wear issue.
SunglassesGuy
84
Oct 27, 2024 10:21 AM
spuds
90
Jan 23, 2024 09:17 AM
d3Performance
Performance
101
Oct 3, 2021 11:38 AM
Petillante
Mar 24, 2021 01:17 PM
Tank
Oct 5, 2020 09:52 PM
