Check VSV message and Engine Light On
Old May 27, 2020 | 12:44 PM
COOLIS's Avatar
COOLIS
Default Check VSV message and Engine Light On
Should I be scared? Hoping this isn’t the actuator!
Old May 27, 2020 | 01:02 PM
ibidu1's Avatar
ibidu1
Just a check engine light, go get it scanned
Old May 28, 2020 | 04:37 PM
COOLIS's Avatar
COOLIS
Thanks! Evap system error - most likely loose gas cap. Easy fix!
Old Jun 5, 2020 | 04:06 AM
Ironman50's Avatar
Ironman50
Common issue - fortunately easy fix - no cost
Old Jun 5, 2020 | 07:21 AM
PauloFR's Avatar
PauloFR
This is just a check engine light, even if it triggers a VSC failure message. Admittedly I freaked out before I scanned the car, then remembered my Volvo V50 worked the same, no clue why.
I had those lights for a bad O2 sensor actually.
Old Jul 5, 2020 | 10:56 AM
Sam756's Avatar
Sam756
Default Check VSC and Check engine light on and vibration
Hi Guys,
I just had the same lights on, and a constant vibration. The rpm is fluctuating. Yesterday just got the water body changed. Any ideas what could caused it and what would be the fix.
Old Jul 5, 2020 | 11:32 AM
ibidu1's Avatar
ibidu1
Originally Posted by Sam756
Hi Guys,
Have who ever replaced your water pump recheck their work, they may have left something loose. Possibly a loose ground or wire
Old Jul 22, 2020 | 11:14 AM
Hrocks's Avatar
Hrocks
With all the crap they put into gas these days, you may never know exactly why it happened. Reminds me of a buddy who used to be an Audi factory race driver. He had a brand new company car for his wife. She smelled gas in the garage. When he went and checked the gas cap, foam shot out of the filler neck. Said it was like an over filled washing machine puking soap suds. Never happened before or after. Go figure.
Old Jul 23, 2020 | 10:16 AM
therednsx's Avatar
therednsx
Talking
I have a 2010 GX460 with 98K, Driven mostly on the highway for long periods of time and then park in the garage for weeks/months at a time after use. I've only seen the aforementioned group of lights come on 2 times. Once for the secondary air injector (replaced by Lexus) and once because I didn't double check the aFe Momentum air intake hump coupler and it wasn't completely seated on both ends.
JohnyUtah
Sep 6, 2022 02:07 PM
ZeekGS300
GS - 1st Gen (1993-1997)
Feb 9, 2009 03:22 PM
vasgs4
May 6, 2005 04:59 PM
