Spherical bearing/knuckle bushing
Old Oct 1, 2019 | 08:35 AM
Blksly06's Avatar
Blksly06
Originally Posted by speedkar9
Ah its a bit of trial and error finding a bushing that will fit. The most important dimension is the press fit diameter.
My brother's G37 has been sitting on jackstands for over a month because we can't find rear lower control arm bushings for it. We had to cut them out because the camber bolt was rusted stuck! Tried Whiteline bushings and the dimensions weren't right. Based on the one removed, we will try another...
Damn man!!!! Sorry you going through my mission too!!! It’s so frustrating especially not being able to move around ugh. I’m still waiting for a guy a eBay the item says it fit up to 07 but when putting my year and model then says it doesn’t I was like huh???
Old Oct 2, 2019 | 06:43 PM
speedkar9's Avatar
speedkar9
Well I got my brother's G37 back together and running today. I had to use Whiteline's bushing calculator online to get one that had the same OD and ID. The length was a bit short so I had to shim it.
http://www.whiteline.com.au/catsize_bush.php
The poly bushings were expensive, $70 for a pair! Beats buying new control arms though.
Carnevino
Build Threads
81
Oct 1, 2019 08:41 PM
wuyanze
Jun 5, 2019 05:56 PM
dito24
Build Threads
22
Sep 17, 2017 10:21 PM
metaleckz
Jun 19, 2017 02:03 PM
MAKAVE22
Mar 27, 2013 07:37 PM
