06 gs430 ! Help
Old Sep 17, 2019 | 10:14 PM
alexis31's Avatar
alexis31
Default RWD vs AWD ? Lexus shopping
Hello ! I am not new too the Lexus family as I have had an ES330 before but never paid attention or took proper care of my car I just drove it put gas and went. Well things have changed lol. I’m now looking into purchasing a beautiful 2006 GS430, fully loaded with 114K miles here shortly but it is RWD. I live in Snohomish Washington and don’t travel up to the mountains or any areas of that sort. Maybe just to Portland here and there.
My main questions are is there any concerns or things I should look out for with this car ? and is RWD in my best interest ? we rarely get snow but when we do I could always just get snow tires right ?
Some people tell me yes get it some say no and maybe get a ES again (don’t want it or an IS) or downgrade and get a GS with AWD option
Just need a few opinions and some good advice ! Thank you
Old Sep 18, 2019 | 04:13 PM
e-man's Avatar
e-man
I live in Chicago. I have driven a GS4 for the past 15 years (99 GS400, 2006 GS430). No issues. But I’ve been driving RWD cars in the snow for my entire driving life (35+ years). Have you driven RWD in the snow before? If you have the luxury of having a second set of rims and winter performance tires for the winter, you won’t have any problems at all.
Old Sep 18, 2019 | 05:03 PM
alexis31's Avatar
alexis31
I have not actually. This is my first time also paying attention to the things on my cars such as what drive train it is. If I did get RWD I was planning on having two different sets... I don’t mind spending the extra money on wheels/rims.
Thanks for your input !
Old Sep 18, 2019 | 05:50 PM
snakeo2's Avatar
snakeo2
ask if the "ABS Actuator" has been replaced? If so when? This a pretty expensive part to replace...approximately over $3,000 in parts and labor if you go the Dealer route. You can also find used ones for $800 or so.
Old Sep 18, 2019 | 06:36 PM
ibidu1's Avatar
ibidu1
Look for an 08-up GS350 awd! The 06 430 is a great very reliable car, but it does have a few things to consider.
1. cost of abs to replace if it ever goes bad
2. 430 uses timing belts that need to be changed, the 350 uses a chain no need to replace.
3. weaker brake system, the 350 uses a more reliable abs system, and bigger calipers.
4. tech inside is older, older navigation, no aux etc
5. front end is older
6. 430 is slower then a v6 350
7. 350 gives you better gas mileage.
I have an 08 350 awd with 180k and super reliable
Old Sep 18, 2019 | 06:51 PM
alexis31's Avatar
alexis31
Good thing to know ! Thank you so much
Old Dec 5, 2019 | 01:58 PM
JayLeap's Avatar
JayLeap
Hi, do any of these apply to the difference between a 2007 and 2008 GS350 AWD?
Old Dec 5, 2019 | 03:58 PM
RXGS's Avatar
RXGS
only front end is older
Old Feb 26, 2020 | 11:16 PM
roshanfiro's Avatar
roshanfiro
Hello,
My GS430 2006 have an issue that all the system diagnostic checks(Sport, Power steering, DIAG TIRE, DIAG VSC, ECT SNOW, air bags) on dial pops up along with this on Screen System check mode. Though finally all the lights disappears with system check mode showing all OK. The diagnostics pops up again . I am unable to trace what is triggering this check as its not popping up on a regular basis.
The screen restarts and again the checks are repeated like a loop. Very annoying as now I cant access the AC or the audio player
Please see the below video
Old Feb 27, 2020 | 01:55 PM
ibidu1's Avatar
ibidu1
Originally Posted by roshanfiro
Hello,
https://youtu.be/macKIXA8zOs
You need to test your electrical system with a volt meter. It sounds like the alternator is going bad, and or could be a bad battery or bad terminals. Testing with a multimeter the with the car off, with the car at idle, and with the rpms slightly up.
Old Mar 4, 2020 | 10:27 AM
KidWeaBoo's Avatar
KidWeaBoo
Calipers and rotors are exactly the same as the 350,unless you can prove me wrong.
Old Mar 4, 2020 | 04:08 PM
ibidu1's Avatar
ibidu1
You are correct! They are not the same smaller calipers that the 2006 GS300 use
wickedtaco
Mar 11, 2020 05:01 PM
gloch
Jul 8, 2013 06:50 AM
endlesslex
Dec 22, 2010 11:33 PM
chuckb
Mar 20, 2005 11:31 PM
