rear door handle sensor question
Old Aug 30, 2018 | 12:42 PM
TS85's Avatar
TS85
Default rear door handle sensor question
Whenever I’m about to hop in my car with a front passenger, I used to walk up to my car and unlock it using the rear passenger door handle sensor. This will unlock ALL the doors for me so i don’t need to unlock for the passenger using my key fob or the inside unlock button. But now when using this method, it only unlocks my driver door and the rear passenger door that I touch to unlock. Can anyone tell me why. I’m thinking it might be a personalized setting because I recently changed my battery.
Old Aug 30, 2018 | 04:42 PM
ibidu1's Avatar
ibidu1
I think you can change those settings using a USB techstream there like $20-40 bucks off ebay and allows you to check codes, personalize etc.
Old Aug 30, 2018 | 05:59 PM
TS85's Avatar
TS85
You’re right, but the cable & software is actually more expensive than that. Ima try and have the dealer adjust it when I bring it in for the recall fuel leak fix.
Old Aug 31, 2018 | 07:13 AM
MX73's Avatar
MX73
Setting probably got reset but I did change my battery recently and I didn't lose the unlock ALL door feature.
Is this happening on both rear and passenger doors? They should unlock all doors. Driver side will only unlock the driver door unless the setting was changed to unlock all doors.
3rd party or "knock-off" cables are not that expensive. I purchased a cable for $15 and include the techstrem software. Just need to know what you're doing.
Old Aug 31, 2018 | 10:02 AM
ibidu1's Avatar
ibidu1
https://www.ebay.com/itm/New-Mini-VCI-J2534-OBD2-Diagnostic-Tool-Code-Reader-for-Lexus-Toyota-Techstream/321761289092?hash=item4aea77a384%3Am%3AmW2IWGk-TsXtaiw7H8U8fbg&var=510669525262
https://www.ebay.com/itm/4033-J2534-...UAAOSwfsFbiRfT
Old Aug 31, 2018 | 10:09 AM
yardie876's Avatar
yardie876
Not sure with the 3GS, but try pressing and holding the lock and unlock keys on the remote until you hear the car beep. That usually switches the door unlocking behavior.
Old Aug 31, 2018 | 11:42 AM
TS85's Avatar
TS85
Thanks everyone. Im gona order the cheap knock
offs since it does the job.
rick3242
Dec 11, 2017 08:09 AM
eyecue
Jul 22, 2016 12:32 PM
jcifuentes
May 2, 2016 07:52 AM
rickpez
May 4, 2014 12:51 PM
galicianer
RX - 3rd Gen (2010-2015)
Sep 7, 2012 10:11 PM
