Washer fluid not spraying out...
Old Feb 7, 2018 | 01:05 PM
user 528962307's Avatar
user 528962307
Default Washer fluid not spraying out...
ten characters
Old Feb 7, 2018 | 06:39 PM
nobelnabil's Avatar
nobelnabil
Not me, I would suggest to turn on the spray and listen for a humming noise (washer pump), if you can hear it then its not the pump. if not then it is either the pump (most likely) or wiring/fuse
Old Feb 8, 2018 | 08:55 AM
PC94's Avatar
PC94
Do you have headlamp washers? If so, have you tried to use those instead of the regular windshield washers to see if those engage?
Old Feb 8, 2018 | 09:05 AM
user 528962307
ten characters
Old Feb 8, 2018 | 10:04 AM
PC94's Avatar
PC94
In your drop-down control panel, there should be a button that looks like a sideview mirror with water on it (see below) --
(Picture taken from online)
With the headlights on, try pressing that and see if you notice the headlights being cleaned.
Old Feb 8, 2018 | 01:04 PM
user 528962307
ten characters
Old Feb 15, 2018 | 05:52 AM
PC94's Avatar
PC94
Hmm ... As nobelnabil asked, can you hear the "humming" noise of the washer fluid pump as it tries to spray out? If you do, you might have clogged washer nozzles that can easily be cleared using a can of compressed air. If not, you might have a bad pump or a blown fuse.
Old Feb 15, 2018 | 04:36 PM
user 528962307
ten characters
Old Feb 16, 2018 | 10:43 AM
PC94's Avatar
PC94
Nice! Gotta love those simple fixes. Glad it works, now.
Israelq95
Apr 17, 2019 04:29 PM
GXoffroad
GX - 1st Gen (2003-2009)
Jan 6, 2017 10:35 AM
dscholl
Feb 17, 2009 08:11 PM
