Headlight Spray Information
Old Dec 22, 2016 | 07:15 PM
mnjeepmale's Avatar
mnjeepmale
Default Headlight Spray Information
I'm trying to get the headlight spray to work on my '08 GS460. I have pressed the button in the drop down panel but the spray doesn't come out and spray the headlight. I only see a small puddle on the ground. This used to work before and also of the headlights has been replaced a year ago.
Is there a trick to make this work?
Old Dec 22, 2016 | 07:24 PM
Fausty's Avatar
Fausty
Try doing it with the headlights on.
Old Dec 22, 2016 | 07:27 PM
mnjeepmale's Avatar
mnjeepmale
I did. Spray still doesn't come out.
Old Dec 22, 2016 | 07:31 PM
Fausty's Avatar
Fausty
if you see a puddle then maybe your jets are clogged
Old Dec 23, 2016 | 06:43 AM
ibidu1's Avatar
ibidu1
Or a busted water line! Put the car on jacks take off the bumper splash gaurd or see if you can access the hoses and pump. Have someone turn on the washers and see what the problem is
Old Dec 23, 2016 | 11:12 AM
mnjeepmale's Avatar
mnjeepmale
I'll look into this. Is there a process for removing the front bumper? I have the document for the rear bumper but not front.
Old Dec 23, 2016 | 02:18 PM
ibidu1's Avatar
ibidu1
You might not need to pull off the front bumper, see if you can just pull the splash gaurd and it may give you access to the damage area
Old Dec 23, 2016 | 02:37 PM
socaligs's Avatar
socaligs
Look if you have the headlight function by looking at the your headlight. My 2010 GS350, I have the headlight sprayer button but my GS does not have the feature.
Old Dec 28, 2016 | 02:22 PM
mnjeepmale's Avatar
mnjeepmale
I'm going to pull the bottom panel off and see if I can find the damaged hose and repair or replace it.
Dante486
Apr 14, 2019 04:00 PM
ChineseKFC
Jun 12, 2018 05:41 PM
mrpartsman
Mar 31, 2015 11:21 AM
ferg5162
Sep 3, 2008 12:12 AM
The Ju1ce
GS - 1st Gen (1993-1997)
Oct 15, 2003 12:15 AM
