SPC Product!!! Bad mechanic !!!
Does anybody know what going on with spc ball joint .. took it to the motorsport shop lowered my gs 450h on tanabe spring nf 210 couple week ago.. look perfect .. after done.. went to alignment shop.. and they told me to get camber kit on it cause it running on the toe...negative.."Stock spring also give me negative eating my tire from inside toe"... so they did whatever they can just to help me... So i order spc product that i heard on this lexus forum is good for my car ...camber kit front and back... but went back to the motorsport shop they installed the spc camber on my gs 450... Done..and guess what happen!!!ONE Front Passenger went up 3/4 of inch like and one inch... or so.. can see the difference and feeling it went back up the rest look real good... talk to my mechanic told him this is a mickey mouse ***** when installing camber kit on my car.. He said it perfectly fine Normal just tell my alignment guy to put weight on the passenger suspension im like... huh?? O.K. But i know it couldn't be done ...So that why im stuck on 1 leg suspension... I'm in Los angeles area i need really good mechanic guy to fix this problem...Or help me solve this problem... It can help me...Oh one more thing is that the mechanic guy work on my front had a very had time taking apart my suspension both front .. bang.. "hammer " on my suspension just to take the old ball joint . also i paid 120 american dollar just to be install all.. i know it not the spc product it my damn mechanic !!!
he probably didn't install the ball joint properly cause one of the sides to be higher than the other.
also check and make sure you don't have spring spacers in there.
everything is supposed to be in nice and tight and the spc ball joint in the front slide into the upper control arm.
the rears you can only get an alignment so much because of the links. you need more than just a camber kit to get the rears straight. im towing in because i don't have the the other arms. just the camber kit.
The GS is built with the driver side higher than the passenger side. You will need coilovers to make both sides even. When I installed my SPC ball joint it did rise it back up alittle. I had to adjust my coilovers to lower it back down.
but that dont true.... why driver side is good and passenger is bad the same measure for all front and back should be the same... 25 1/2 inch same all in one front and all back the same measure but the passenger side is 26 1/4.. .... huh.... mmmmm that weird ... when i check that ball joint is put in correctly.....
Tanabe NF (Nice Feel) is hardly a drop, if you were on the DF then maybe justifiable. NF oem is fine, theres plenty of people running them with out any issues.
I think you have one of two issues
A: Your car was in an accident that has tweaked your suspension
B: Your alignment guy doesnt know what he is doing
Your eating toe in the front or rear? GS's some have issues with the rear, which is what I had. SPC rear chamber bars cured my rear toe issue.
check the spring nothing wrong...i think it the arm that hold the suspension ...
