Adding after market amplifier questions
Old May 27, 2014 | 06:59 PM
DrexLex's Avatar
DrexLex
Originally Posted by XxGoKoUxX
Ohh no, I mean, why should he worry about his gains on the amplifier cooking the factory amp? The factory amp is just acting like a signal processor itself (sort of), isn't it? What really bugs me is HOW is the factory amp popping caps when all it is acting like, is a signal out, driving nothing but a sound signal to the bit one?
If the original Bit One installer connected the factory outputs incorrectly, for example like tying the speaker negative output(s) to ground instead of the "-" inputs of the Bit One, the amps could have been damaged (although they should have been ground short protected by design). Who knows. That's why I'm asking lots of questions. If, for example, the - outputs are toast, but the + outputs are still OK, then it would be fine to drive the Bit One from only the + speaker signal.
Old May 27, 2014 | 10:12 PM
XxGoKoUxX's Avatar
XxGoKoUxX
Gotcha, I don't know how an installer can screw that up.... Not saying you're wrong, but maaaaan, you gotta be pretty dun duh duh to mess up the amp. I'm a beginner in car audio (by no means am I an expert) and I couldn't mess THAT up.
BrianTyler
Apr 8, 2013 02:39 PM
tcorder
Dec 13, 2012 07:50 PM
Krik
Mar 28, 2012 08:31 PM
LexGX
GX - 1st Gen (2003-2009)
Jun 17, 2008 02:39 PM
