Tail light has water
Old Apr 18, 2014 | 04:50 PM
Majek's Avatar
Majek
Default Tail light has water
Hey guys, I noticed one of my tail lights has water inside, so there is some leak. I first noticed it after a touchless carwash.
How do I remove the tail light assembly so I can inspect it and dry out the water?
What's the best way to seal the hole (if there is one) causing the leak?
Thanks.
Old Apr 19, 2014 | 12:43 AM
XxGoKoUxX's Avatar
XxGoKoUxX
It's a straining procedure, remove the rear carpet panels, unbolt your taillights, bake the taillights, remove the glue and reglue again.
Old Apr 19, 2014 | 07:37 AM
SoCal_450h's Avatar
SoCal_450h
I don't think bake procedure will work, they're plastic welded..
Old May 7, 2014 | 02:33 PM
Majek's Avatar
Majek
The leak is caused by a separation of the seal at the top of the light. This happened during the brutal winter we had. I think it might have to do with the pressure I applied a couple of times to get the frozen ice off the tail light
It's dry now. I think I will apply clear silicone at the top. I could also use a heat gun and open up the light to clean off a few water stains.
Old May 7, 2014 | 09:06 PM
XxGoKoUxX's Avatar
XxGoKoUxX
WTH? I thought they were like the headlights, glued on... LOL you learn something new everyday!
Don't think you can do that if it's plastic welded... I did light googling, and "ultrasonic welding" is not undoable, you might have to just bite the bullet and epoxy/clear silicone over it.
GL!
Old May 8, 2014 | 01:15 PM
Majek's Avatar
Majek
That sucks if they cannot be separated.
Do we have evidence that the tail lights are permanently plastic welded? Has anyone taken apart the tail light?
Old May 8, 2014 | 06:27 PM
BinaryJay's Avatar
BinaryJay
I would just wait for a very hot sunny day, park it in the sun, let it evaporate out and then run a bead of silicone around it where you can and trim off anything visible after. I would not have the patience to do a perfect job of removing it etc.
Old May 8, 2014 | 09:26 PM
XxGoKoUxX's Avatar
XxGoKoUxX
He wants to remove the residue left in the lens of the taillight, which sucks
Old Mar 8, 2015 | 12:37 AM
dicer's Avatar
dicer
Silicone will not last. I'd use a clear 2 part epoxy instead.
DennisMik
Apr 20, 2016 11:57 AM
Lveyolfe
Jan 15, 2016 08:30 PM
afang
Apr 22, 2009 07:58 PM
KPC
IS - 1st Gen (2001-2005)
12
Feb 11, 2007 06:05 PM
thebanez
Sep 3, 2005 02:20 PM
