HID issues...
Old Apr 9, 2013 | 08:29 PM
bluntdaddy's Avatar
bluntdaddy
Default HID issues...
Hi everybody,
I am new to this forum and just wanted to start by saying everybody has some badass cars here. Can't wait to have fun with mine okay back to the point, I just put hids on my headlights and fog lights. Every time they turn on, it's either one headlight is out or one fog light. I just need to turn it off n back on and then it's fine. I did some research but couldn't find anything related. Sometimes all of them will work once turned on but one or the other will go out while I'm driving. I do have d4S bulbs on them. It is getting really frustrating... Anybody have similar issues with aftermarket hids? Could it be that I got faulty bulbs? Any help is appreciated.
Old Apr 9, 2013 | 09:04 PM
06whiteGS's Avatar
06whiteGS
It's difficult to say what the issue is??? U might want to start with a new set to see if u got faulty bulbs?? Try exchanging them to see if that's the case which hopefully it is.... U don't want to have a ballast issue cause that a lot of $ to replace! Good luck with ur issue. I had the same problem and it turn out that I needed to replace my HID's bulbs.
Old Apr 9, 2013 | 09:09 PM
bluntdaddy's Avatar
bluntdaddy
Thanks! I hope I just got faulty bulbs..
Old Apr 9, 2013 | 09:57 PM
worker's Avatar
worker
are they new bulbs?
Old Apr 10, 2013 | 04:17 AM
IXI187IXI's Avatar
IXI187IXI
ballast are not a lot of money if you need to replace them. they can be had for $70 a piece on ebay.
if it was the ballast they wouldnt come on after you turned them off and back on. its more than likely the bulb. are they cheaper bulbs?
Old Apr 10, 2013 | 06:12 AM
LexG's Avatar
LexG
I had the same issue but with the stock HID bulb. One side would come on fine and all the sudden turn off. In order get back on was to turn lights off and then back on. I swapped bulb with other side and problem followed so I replaced both bulbs with new ones and have never had the issue since. I would say swap and see if issue follows, most likely bad bulbs. Good luck.
Old Apr 10, 2013 | 06:45 AM
c-low's Avatar
c-low
where did you buy the bulbs? i had some from DDMTuning and they didnt work so hot..... switched to garax
Old Apr 10, 2013 | 11:49 AM
bluntdaddy's Avatar
bluntdaddy
Yes they are brand new bulbs. I got the bulbs from ijdm toys. Anybody heard of them? Also, it's not only one side that keeps going out. Both of them randomly go off n on. Sometimes even both of them will be out at one point.
Old Apr 10, 2013 | 12:17 PM
sirblinks's Avatar
sirblinks
I got some Phillips bulbs for 100 bucks from JLC lighting in El Monte. So far so good, and legit! ( i hope).
Old Apr 10, 2013 | 12:18 PM
IXI187IXI's Avatar
IXI187IXI
well thats the place you bought therm from not the brand of the bulbs. do you know the brand that you got? i think it might just be cheap bulbs.
Old Apr 10, 2013 | 12:56 PM
bluntdaddy's Avatar
bluntdaddy
ooh haha, I'm going to have to ask my friend... he was the one who got them for me. I appreciate everybody's input!
pip235
May 23, 2017 08:42 PM
xmike714x
May 14, 2015 01:00 PM
nebojsa
Mar 1, 2013 05:37 AM
seouljahon
Lighting
Mar 25, 2012 12:06 AM
NXOwner
Oct 23, 2007 10:36 AM
