Do I need extend studs?
Dec 27, 2012 | 09:53 PM
Hello. Do I need to replace to longer studs if I put 5mm spacer on?
Dec 27, 2012 | 10:55 PM
Nope. But anything longer than 5mm is when you would need extended studs. Make sure you torque them completely and torque again within a week or two.
Dec 27, 2012 | 11:06 PM
Thanks. Do I need to torque it every week or two? or just once time thing
Dec 28, 2012 | 12:21 AM
Wow, didn't know you could run 5mm's with OEM studs! Isn't that risky?
Dec 28, 2012 | 01:39 AM
Depends a lot on your rims, and how thick your hub is on the wheel. Buy it, and try it! Worst case you run to napa and buy some longer studs.
Dec 28, 2012 | 06:53 AM
many on here are running with out extended studs, I wouldn't risk it. This is where custom rims are best so you don't have to use them period.
Dec 28, 2012 | 10:13 AM
i did 5mm and i didnt need them you will be ok
Dec 28, 2012 | 12:52 PM
Quote:
Originally Posted by
Mike1970
but you have custom wheels lol
Dec 28, 2012 | 01:41 PM
passnu2
I agree with Mike. I wouldn't risk it. Not worth the safety factor, IMO
Dec 28, 2012 | 05:06 PM
I agree that 5mm it is not necessary. Done it on several cars w o any problems. Anything larger yes.
Dec 28, 2012 | 05:56 PM
JH48
No, just one time thing a couple weeks after you put your wheels on to make sure they stay on tight. If you ever loosen all your lugnuts and take the wheel off I'd recommend doing it again.
Dec 28, 2012 | 06:10 PM
swtjlsy
very true
ApokC
Mar 26, 2012 07:31 AM
Vip.Status
May 17, 2011 04:54 AM
bio3m
May 10, 2011 10:56 PM
joeker
Suspension and Brakes
Oct 6, 2010 02:15 AM
racinjasin
Dec 5, 2008 02:32 PM
