Loud Pop!
Old Dec 4, 2012 | 09:52 PM
1SLOGS's Avatar
1SLOGS
Default Loud Pop!
Its been a few months since i had my coilovers installed now. Past 2 to 3 months i have been hearing a loud pop when i turn my steering wheel when stationary so asked around and some of them told me it maybe my Tie rod. Another strange thing is that this pop comes at times and doesnt at sometimes which is strange and when i jack up the car and stuff i dont hear it at all also when the car is on smooth surface like in a Garage or something i dont hear the pop at all. I dont seem to know where the Loud pop is comming from and cant seem to pin point it. I want to know if anyone one else has faced this problem? Also when i jacked the car up to see the issue everything looked fine even my CV axle looked fine no wear and tear on it or anything. Also if its my Tie rod has anyone tried to replace them and fix theirs ?
Thank you In advance
1SloGS.
Old Dec 5, 2012 | 08:25 AM
designo's Avatar
designo
Hmm, top mounts?
Old Dec 5, 2012 | 04:23 PM
1SLOGS's Avatar
1SLOGS
Originally Posted by designo
Hmm, top mounts?
I have no clue its been popping lately for some reason and i cant seem to find it. but ill take a look at the top mount and see if its that. Thank you.
Old Dec 5, 2012 | 05:02 PM
ibidu1's Avatar
ibidu1
Best thing to do is lay under the front of the car and have someone turn the steering wheel. You should see where is comes from, because it could be a number of things.
Loose bolts on the coilsover
Loose steering rack
tie rod
ball joint
A-arm bushings
Top perch of the coils
Old Dec 5, 2012 | 06:10 PM
1SLOGS's Avatar
1SLOGS
Loose steering rack
tie rod
ball joint
A-arm bushings
Thanks for the info ill check it out i guess ill have to raise my car up so i can get under it.
Old Dec 28, 2012 | 01:40 PM
tsaxton01's Avatar
tsaxton01
i had the same problem. its really embarrassing. I had a friend of mine just replace my pads and rebuild my brake calipers. I no longer hear it anymore. You may have a clip missing from your pads or you may have a locked up caliper all together. If the caliper is locked. they just lube it up really good. Locked caliper equals pads sticking!
Old Dec 29, 2012 | 11:06 AM
1SLOGS's Avatar
1SLOGS
We Pinpointed the problem and found out that its my outer tie rod thats knocking on my Brake Cover thats behind the Disk and the guy who checked it told me i must have hit a pothole which must have caused it to move out of place and i remember that i was driving thru NY and hit a really bad pothole in the lincoln tunnel and thats what must have done it.
Nickk6
GX - 2nd Gen (2010-2023)
Apr 24, 2017 08:39 AM
Jbthompson
Apr 22, 2016 03:14 PM
Verge
GS - 1st Gen (1993-1997)
14
Apr 14, 2008 06:04 PM
infa_red
13
Jun 10, 2007 11:41 AM
Panerai127
Suspension and Brakes
17
Apr 3, 2007 08:25 AM
