Wheels leaking help
Old Nov 3, 2012 | 10:22 AM
JH48's Avatar
JH48
Exclamation Wheels leaking help
I dont know why the two front of my wheels keep leaking in few hours after filled up the air. Im running on 235/35/19 on 19x9.5 it doesnt seem stretch that much though. any help will be nice
Old Nov 3, 2012 | 12:41 PM
0975788's Avatar
0975788
try taking it to a tire shop. see whats the problem for free. Discount tire?
Old Nov 11, 2012 | 09:47 PM
Herndog532's Avatar
Herndog532
pothole, new seal, valve stem leak. could be anything. take it to a local tire shop
Old Nov 11, 2012 | 10:07 PM
Lextrician's Avatar
Lextrician
could it be leaking from the beads???? take them to a tire shop they will check it with water to be sure I would take em off and submerge in water to see if there are any bubbles, you find bubbles you will find the leak this way you will atleast know what is going on.
Old Nov 12, 2012 | 05:49 PM
arnieosp's Avatar
arnieosp
I you have chrome rims, the chrome sometimes gets loose and peels off the metal, which would cause a slow leak. I had that problem with chrome rims on my old Maxima few years ago.
Old Nov 12, 2012 | 05:55 PM
Timothyj's Avatar
Timothyj
Had the same problem with my 04 ES. Tires are 3 years old, Michelin, great tires, but still seem to leak a little . I think its my rims, aluminum rims change a lot with the weather.
Old Nov 12, 2012 | 07:59 PM
circuit022's Avatar
circuit022
Try inside bead... I would just tell a tire shop to put bead seal on it and call it a day
Old Nov 13, 2012 | 06:39 AM
BinaryJay's Avatar
BinaryJay
Corrosion can make this happen. Shop will remove tire, sand down the inside and then remount should fix it.
LMoney4o8
Wheels, Tires & Brakes Forum
Nov 16, 2023 11:04 AM
Drabek
Mar 12, 2011 04:26 AM
jonathancl
Mar 10, 2009 05:10 PM
laser_doc
Jul 30, 2007 10:01 PM
f15skipf16
May 1, 2007 11:23 AM
