Last edit by: IB Advertising
Browse all: General Overview
- Warning Lights
Important information to help you understand your Lexus
help: 2006 gs300 warning lights galore
just had some lights pop up, was wondering if anyone could tell me what they mean?
Here is a photo with the lights that came on.
Any help would be appreciated. Thanks
Vehicle Stability Control issue.
Have a look in the owner's manual, see if anything obvious is cited as potentially causing it which you can control/rectify.
If not, then it'd be worth contacting your local dealer to have it diagnosed, or a good independent who can service Toyotas.
Something makes me want to say ABS or speed sensor, but I could be (probably am) misremembering that from another thread - so best not latch on to that as a diagnosis or fix.
https://www.clublexus.com/forums/gs-...check-vsc.html
https://www.clublexus.com/forums/sea...archid=9069594
Same problem was fixed on my Ls 400 by cleaning out the throttle body with a spray, I also cleaned batt terminals. Not sure which helped but that did it.
Autozone can check your codes for free. Go from there.
https://www.clublexus.com/forums/gs-...eck-vsc-4.html
Looks like the gas cap from this thread...(page 4)
craigsroto
Apr 16, 2013 10:46 AM
