Trunk Wont Open Electronically, $1500 fix?!?
Old Sep 23, 2011 | 09:00 AM
vaLency's Avatar
vaLency
Default Trunk Wont Open Electronically, $1500 fix?!?
Long time reader, first time poster...
So recently my trunk stopped opening electronically. I can manually open it with the key, and the button in the glove compartment is engaged. Took it to the dealer to get checked out (among other things) and they claimed it's a known issue under LSB-0123-08. An entire junction box needs to be replaced along with a wiring harness. Total cost for the repair around $1500.
I have been unable to find this Service Bulletin, and am shocked by repair cost. My trunk will remain broken for the foreseeable future, anyone have further info or similar issues?
Thanks.
Old Sep 23, 2011 | 01:31 PM
lkapimp216's Avatar
lkapimp216
Sounds like a pile of BULLS.H.Y.T.
Old Sep 23, 2011 | 02:01 PM
worker's Avatar
worker
There is a way to disable opening electrically... you might accidentally did that.
Old Sep 23, 2011 | 02:10 PM
rominl's Avatar
rominl
exclusive matchup
but he said in this post that the button in glove box is in the right position already
Old Sep 23, 2011 | 05:20 PM
retrospex's Avatar
retrospex
$1500?! what crooks, I would've threw coffee all over their paperwork if they said that
Old Sep 23, 2011 | 05:30 PM
L3XOTIC's Avatar
L3XOTIC
stealership price. If it is indeed that issue, most reputable repair shops will do it for half that cost.
Old Sep 23, 2011 | 06:05 PM
GS350Lexus's Avatar
GS350Lexus
Yes that price is about right, I would just DIY that thing. Go to sewellparts.com and order the piece.
Old Sep 23, 2011 | 08:15 PM
dentalstud's Avatar
dentalstud
before you pay $1500 to replace something, try unplugging your battery and leaving it out for about 10 minutes to reset the electronics. the same thing happened to me when my alarm installer was checking wires with his powerplay tool. when you push the trunk button, do you hear a relay from within the vehicle? for me, i heard the relay in the vehicle, but the trunk did not release/open. good luck!
Old Sep 25, 2011 | 01:16 AM
arnieosp's Avatar
arnieosp
Also, if you do have to replace it, check junk yards around. Electronics are usually hugely expensive at dealerships, but you can get them for close to nothing at a junk yard.
Old Sep 25, 2011 | 12:06 PM
Phureallin's Avatar
Phureallin
thats a little bit too expensive !!
Old Sep 25, 2011 | 03:58 PM
*Batman*'s Avatar
*Batman*
This is the problem with this soft-close stuff. It helps Lexus sell new cars, but once the car is out of warranty, the repair costs are going to be astronomical.
You either have to put up with stuff like this, or buy a newer car. It's too expensive to own out of warranty imo. The side mirrors are also expensive out of warranty replacements.
Old Oct 14, 2011 | 09:06 AM
juggs787's Avatar
juggs787
I just started having the same issue yesterday after my fiance took the car in for an oil change. Im gonna see if I can find the trunk disable button then try disconnecting the battery.
Old Oct 14, 2011 | 03:14 PM
TWong350's Avatar
TWong350
CL Folding 10,000
Wow...$1500 is steep! Attached is the TSB for this. The part number is 82730-30273. Quick Google search shows about $571 for the part. The TSB shows 1.2 hours as the flat rate given to the tech to repace it. $921 for an hours worth of labor.
Try to acquire one used and replace it yourself. Step by step instructions attached.
File Type: pdf
Old Oct 14, 2011 | 07:14 PM
Stormforge's Avatar
Stormforge
executive matchup
twong1200, thx for posting the pdf instructions. should come in handy for everyone who needs it
rhwimmers
Dec 17, 2016 12:03 PM
Lukas99GS
Jul 31, 2016 10:12 AM
bobnxena
Oct 8, 2010 05:02 PM
business1s
Jun 3, 2010 08:07 PM
montgb
Jul 9, 2006 05:37 PM
