Vaistech ML Plus
Old Sep 20, 2011 | 09:20 PM
Tomcio78's Avatar
Tomcio78
Default Vaistech ML Plus
Hi,
Has anyone installed the Vaistech ML Plus in their GS350 with navigation? I recently purchased this and have it hooked up but (love it works great and I can watch videos as I drive.. yeah!!!!!! ). The only issue I'm having is I'm not sure where I can mount this... tried behind the radio and its too big. tried under passenger side seat and not enough room... Anyone out there that has this installed please let me know where and how you got this installed.
Old Sep 20, 2011 | 11:04 PM
rominl's Avatar
rominl
exclusive matchup
the gs is a very tough one. i got perfect spot for it on both the 2is and 4ls, but on the 3gs i have yet to find a really good place to completely hide it. behind the radio is hopeless. the gap between radio and nav, not enough. above glove box, no space. below glove box, no space. behind glove box / around, don't recall enough space. no space behind passenger side carpet underneath glove box. on the installs i have done so far, it's on the side of the center console behind carpet, but it creates quite a bulge. customers think it's ok, though i think it's a bit obvious. i am still hunting for the right spot
Old Sep 21, 2011 | 02:04 AM
XxGoKoUxX's Avatar
XxGoKoUxX
have you guys thought about extending wires long enough to get it into the trunk? You can run wires back and forth to and from the trunk, it will make a much cleaner install.
Old Sep 21, 2011 | 06:22 AM
Ashdaddy's Avatar
Ashdaddy
Originally Posted by rominl
On the installs i have done so far, it's on the side of the center console behind carpet, but it creates quite a bulge. customers think it's ok, though i think it's a bit obvious. i am still hunting for the right spot
Mine was installed there as well. Side wall of the passenger side footwell, but removed the foam & cut the plastic wall back there to create a pocket for the unit. Fits perfectly, & no bulge at all. USB is tucked up under the leather console trim for easy access.
Old Sep 21, 2011 | 06:30 AM
tmv22's Avatar
tmv22
how do you run wires back to the trunk???
i was sweating getting the dashboard out. hopefully running wires to trunk wont require removing seats around
Old Sep 21, 2011 | 07:03 AM
ItsMeTarry's Avatar
ItsMeTarry
does this unit have the Nav/Bluetooth unlock? i know it has the video in motion feature though
Old Sep 21, 2011 | 08:05 AM
msgs350's Avatar
msgs350
I was just asking rominl this same question yesterday. I'm considering having the dealer install it just so I can see where they mount the unit. I know if I did it myself, I'd follow rominl's suggestion of placing it behind the carpet.
Old Sep 21, 2011 | 08:08 AM
HUSKERnKS's Avatar
HUSKERnKS
Mine is behind the nav/head unit without a problem. It is a little tight, but I tucked it into the corner towards the drivers side. I added Velcro to keep it from moving and even zip tied it. I had to make sure the wires were nice and tidy, but it fits and the whole nav unit fit back in perfectly.
I then ran the iPod plug and USB port into the glove box. There is a nice little door on the left side that opens up. I cut a small notch into that so it would shut.
Old Sep 21, 2011 | 08:42 AM
rominl's Avatar
rominl
exclusive matchup
probably a little tough. there is the digital video cable and i don't think that's something you can just extend like other wires
no it doesn't
interesting, i will definitely need to take a look again next time i install. i think in that location just need to be very careful to avoid rattling with any other parts
Old Sep 21, 2011 | 09:12 AM
HUSKERnKS's Avatar
HUSKERnKS
I was definitely worried about rattling, so I used the Velcro as padding and holding it in place. I have it standing on end, meaning it is taller instead of wider. That helped it fit.
I have had 0 issues. I originally had tried your idea of under the carpet but took it out to try behind the unit again. Very glad I did.
If I ever take out my head unit again (don't plan to), I will take pictures of how I have it in there.
Old Sep 21, 2011 | 12:07 PM
rominl's Avatar
rominl
exclusive matchup
that's awesome, great tips. i will definitely look into that!
Old Sep 22, 2011 | 12:08 AM
XxGoKoUxX's Avatar
XxGoKoUxX
no it doesn't
Sorry about that, I wasn't thinking about how much wire would be involved to drag from behind the unit to the rear of the trunk, and on top of that how much wire it will take to drag from the back of the trunk back up front for video feed x.x
I guess someone solved that problem by getting it to fit behind the nav unit
Old Sep 22, 2011 | 11:52 AM
Tomcio78's Avatar
Tomcio78
How the heck did you manage to put it behind the radio?????? I tried to do the same and no luck... I huffed and I puffed trying to push the navi back in but ended up giving up since I did not want to brake it... The wires are too long and take up too much space... any tips you can provide would be awesome.
Old Sep 22, 2011 | 11:54 AM
Tomcio78's Avatar
Tomcio78
You wouldnt happen to have any pictures of this????? Who did the install for you,, Dealer or yourself?
Old Sep 23, 2011 | 08:08 AM
Ashdaddy's Avatar
Ashdaddy
Mike with Custom Installation and Design at 847-899-3600... Charged me $100 and came to me to install. I live in Chicago. They do the custom a/v work for McGrath Lexus.
