Tire Question
Old Jul 7, 2011 | 06:44 AM
mikedozz's Avatar
mikedozz
Default Tire Question
Hey Guys, I had my awd lowered on 20s, but raised her back up because of the vibrations and wobble. Since then, I have brand new Lorenzos and I just bought cheap tires, Federals, all 4 cost me 550 installed. I'm getting a vibration feeling over 40mph when I drive, I know these are noisy tires to begin with, but do you think something is wrong besides that? 245-35-20.
Old Jul 7, 2011 | 06:48 AM
IXI187IXI's Avatar
IXI187IXI
do you have hub rings? how were they balanced?
Old Jul 7, 2011 | 08:23 AM
designo's Avatar
designo
AWD, Lowered, 20's?
I think tires are the least of your concerns.
Old Jul 7, 2011 | 08:28 AM
mikedozz's Avatar
mikedozz
Hey guys, I was lowered, but went back to stock springs because of wobble-vibrations. I believe I have hub rings, those are the metal ring that goes on the hub before you put the wheel on? The reason why I know that is because when I didn't have it on, my rims rubbed against the break caliper.
Old Jul 7, 2011 | 08:56 AM
rominl's Avatar
rominl
exclusive matchup
no, what you described is spacers. and i have a feeling you don't have hub rings, which will help to center you wheels better with the hub to avoid vibrations
Old Jul 7, 2011 | 08:57 AM
IXI187IXI's Avatar
IXI187IXI
hub rings and spacers are 2 different things. a hub ring will not push your wheel out for clearance. all a hub ring does is will in the void between your hub and the center bore of the wheel.
Old Jul 7, 2011 | 11:29 AM
mikedozz's Avatar
mikedozz
Thanks!! I think I know what u are talking about now, is it a thin plastic almost milk cap circular hub? If so, I have to see if my friend put them back on, he probably removed them when we put the stock rims back on in the winter.
Old Jul 7, 2011 | 03:20 PM
designo's Avatar
designo
When you wheel fits onto your hub, there should be little to no play at all! If there is, then your hub bore and wheel bore are not matching!
st1800
Jun 18, 2018 12:19 PM
STR
Jun 7, 2012 07:28 PM
Stokeless
Mar 1, 2011 08:32 PM
joeker
Wheels, Tires & Brakes Forum
Jun 22, 2010 05:47 PM
lexboi250
May 19, 2008 01:48 PM
