Dash noise fix success rate ?
Old Mar 23, 2011 | 06:43 PM
  #31
98OysterES's Avatar
98OysterES
Originally Posted by Bavaria
I may be wrong, but isn't this covered by a TSB? If so, my understanding is it would be done regardless of whether or not the car was under warranty.
Recalls are usually regardless of mileage / warranty ... TSBs are not!
Old Mar 24, 2011 | 10:17 AM
  #32
Bavaria's Avatar
Bavaria
I stand corrected. Thanks.
Old Feb 2, 2012 | 05:36 PM
  #33
edwin1027's Avatar
edwin1027
Originally Posted by mrblack
Mine was done month or two ago and so far so good. 2007 with 27k miles. Wasnt bad before I brought it in either, had only just started hearing the "creak/squeak" and a few rattles over bumbs on occasion when I made the appt.
I need to hunt down a noise in my seat though. Dealer states they dont hear it..
May be a slightly loose or rubbing spring or wire thing the seats or framed with in the lower back area. A tick/click sound when weight shifts in turns. Cant reproduce by moving my body around in the seat only when car is going through curves or turns. Havent taken the seat apart to look yet though.
A tick/click sound when weight shifts in turns, did you solved this problem? If yes, please let me know how. I'm having same issue after 64K miles !!!
Old Feb 3, 2012 | 10:02 AM
  #34
patricksr5's Avatar
patricksr5
I have about 70K miles on my '08 and had a creaking dash. Since I have an extended warranty and had all my work done at Lexus, Lexus agreed to pay for taking out the dash and looking for the problem. It took 2 trips to the dealer but they found something in the cowl area which eventually mostly took care of the problem. 3 months later and I am starting to hear the same creaking starting to come back. Not as bad...but starting to come back. I give up...my GS is reliable (no engine or drivetrain problems) but the creaks and rattles drive me nuts.
NobleSpine
Sep 3, 2020 06:36 PM
GunnyFitz
Sep 2, 2020 09:21 AM
lexus-is2
Nov 17, 2014 07:01 PM
Lex08350
Jul 16, 2008 05:55 PM
GRAYM
RX - 1st Gen (1999-2003)
Nov 5, 2002 02:10 PM
