Replacing Interior Lights-2006 GS300
I have searched the entire forum on how to replace the interior LED's, specifically the front and rear dome lights (the 2 dots that turn on when the door is opened). I hear that those LED's are soldered in the circuit board. Is there any DIY threads that would describe how to replace? I also want to change the courtesy door lights.
I'd appreciate any help. Thanks.
jremitio
Look here
https://www.clublexus.com/forums/gs-...or-lights.html
In brief, I what to put these in courtesy door lights
http://www.v-leds.com/Exterior-LED/C...00874-1-3.html
Look here
jremitio
Look here
Look here
Hmm... i want to cut wirres in door lights, cuz there is no standart 194 socket. It is not possible to change bulbs.
Dome lights = interior lights ?
No! the same story. OEM housing with OEM Lexus LEDs. Not standart socket.
You can change easily only these lights (see atached pic)
* i don't know how to call them in english, english is not my native language ...
I will do my foto-review
"Do it yourself" consists only of cutting two wires
So there will be no DIY if i do it. Just lots of pics.
Here is DIY in few words - you remove LED housing from door, unplug or cut the wires, stick the V-Leds small circuit on original LED housing, connecting wires to new V-Leds circuit board and that's it!
OK, I will show in pics. But it will take me 1 month to get this V-Leds circuit boards. Then I will show in pics, step by step if you wish.
There is a guy On here called the led guy he can do any type swap you want to do with your interior lighting even if it's soldered in place. He does complete dash swaps in less than a day to swap out every dash light in the dash check him out on here
fordsvtmfl
Jan 7, 2011 05:38 AM
