Shark Fin no XM???
Old Apr 20, 2010 | 07:51 PM
LexusVRGN's Avatar
LexusVRGN
Default Shark Fin no XM???
I just bought an 07 GS 350 AWD. I thought I had xm since I had ML and shark fin and AM/Sat button. Is this not right. Can you actually have all that and not have XM?? I'd not how do I get to it. Button does not get me there.
Old Apr 20, 2010 | 07:56 PM
2001LexusIS300's Avatar
2001LexusIS300
shark fin is standard on all the cars
Old Apr 20, 2010 | 09:15 PM
*Batman*'s Avatar
*Batman*
The car is prewired for XM so all cars have the antenna. Sharkfin is shared between radio, GPS and Sat radio as far as I am aware.
The pre-wire makes it easy to install - only need to install the xm reciever no need to wire a new antenna. But you do have to buy the OEM XM reciever.
Old Apr 20, 2010 | 09:25 PM
jason60050's Avatar
jason60050
Unfortunately no...however for 2010 they come standard with XM.
Old Apr 20, 2010 | 10:44 PM
TWong350's Avatar
TWong350
CL Folding 10,000
Where is the XM receiver mounted anyhow? Somewhere in the trunk I suppose?
Old Apr 21, 2010 | 06:26 AM
LexusVRGN's Avatar
LexusVRGN
The Antenna is mounted on the roof. It's the shark fin as far as I am aware.
Old Apr 21, 2010 | 06:50 AM
IXI187IXI's Avatar
IXI187IXI
not true. not all the 3GS; have the shark fin. Some of the people who do not have the shark fin antenna buy one and just stick it on for the look.
Old Apr 21, 2010 | 07:25 AM
TWong350's Avatar
TWong350
CL Folding 10,000
Well, I know that the antenna is on the roof (as I have a shark fin on my 3GS). My question was where is the XM receiver mounted?
Old Apr 21, 2010 | 07:29 AM
3GS404's Avatar
3GS404
i've 06'GS and Mine is install on inside of the trunk... don't we have to pay for to listen to XM??
Old Apr 21, 2010 | 01:59 PM
rominl's Avatar
rominl
exclusive matchup
not exactly. the gps antenna is mounted somewhere else.
i don't know about the gs, i thought the radio antenna is integrated into the rear windshield. in 06 gs, shark fin antenna was an option, not all had it. in those cars the radio antenna had to be somewhere else
oem xm receiver is mounted in the trunk, upper part. i have studied it pretty well before
and oem receiver is not the only option, you can also get vaistech. you can get an adapter which will then allow you to reuse the factory shark fin antenna for xm (or sirius).
cost wise, getting vaistech is usually a bit cheaper than oem
Old Apr 21, 2010 | 02:00 PM
rominl's Avatar
rominl
exclusive matchup
yes you need to pay for subscription
Old Apr 21, 2010 | 02:21 PM
3GS404's Avatar
3GS404
getting vaistech is usually a bit cheaper than oem[/QUOTE]
Agree w/ Henry..
Old Apr 21, 2010 | 02:38 PM
jason60050's Avatar
jason60050
I have the USB in my center console so I just plug that into my phone and use the internet radio for free on my phone and it sounds pretty good through the speakers.
Old Apr 21, 2010 | 03:27 PM
TWong350's Avatar
TWong350
CL Folding 10,000
Weird. I have XM radio and haven't noticed anything mounted in the trunk, aside from the ML amp. I know it doesn't have a VAIS unit either, aside from the SL2i-up I installed. Blah, oh well!
Old Apr 21, 2010 | 03:37 PM
rominl's Avatar
rominl
exclusive matchup
when you open up the trunk, look at the bottom side of the rear deck, toward the passenger side (by the hinges cover). it should be there. technically to install it, the trunk lining has to be cut to expose part of the xm tuner
in terms of installation i think doing the vaistech is a tad easier, the trunk install it a bit more involved
